So gets bearings fi...
[Closed] So gets bearings fitted and now there's a bit of play in the bushings so....
[#4929403]
LBS has said if I take the shock down to them and supply the bushings they will fit them for nowt.
So basically i'm after tips, pointers, does and don'ts for removing a Fox RP2.
Hit me with em!
Posted : 05/03/2013 9:32 am
Undo bolts. Remove shock.
Posted : 05/03/2013 9:37 am
On a pitch?
Support the bike under the saddle or even the bb so the swing arm doesn't compress making things harder.
Undo the top bolt and remove.
Undo the bottom bolt and remove.
Take to lbs with beer/cake as a thank you.
Posted : 05/03/2013 9:38 am
Yeh ont Pitch - cheers for that 😀
Posted : 05/03/2013 10:13 am
 sv
6mm hex on top and 4mm hex/11mm nut on the lower mount.
Posted : 05/03/2013 10:48 am
