Well (and I can't believe I'm having to explain this).
'From' is often used in adverts to suggest that if you want the model in the picture then it'll cost more, but the basic spec is £x
So that's potentially misleading - it often gets complaints to the ASA.
However, in this case, it's done the opposite, in that you thought it meant the above, but in fact doesn't. You can actually get the pictured model for the advertised price of £2499.
I'm not even sure there is even a higher model (XX1, dual position, CCDBACS is all I can think of), so perhaps the 'from' was just left in from a page template by the artworker or something.
So you're saying it doesn't make sense? I agree with you.
I believe clarification is needed.
Yes
Perfect 😀
Change the price to 499.99 too please
I hope everyone is keeping a note of their time spent, so that STW can invoice On-One for consulting related to at a minimum the following: QA, Proof Reading, Marketing, backoffice IT and website design.
On-One Codeine 29er Frame
Rockshox Pike RCT3 140mm Solo Air / Tapered / 29 Inch with 15mm Axle / Diffusion Black / Crown Adjust
Cane Creek Double Barrel Air / Black / 190mm / 50mm / 22.0mm Front 22.4mm Rear x 8mm
Rockshox Rear Maxle Lite / 142mm x 12mm / Black
On-One Smoothie Mixer Tapered Headset 1 1/8 inch - 1.5 inch / Black / Mix Tapered
On-One TECH Series CNC Quick Release Seatclamp / 34.9 mm / Black
On-One Spacer Set 20+15+10+5 / 1 1/8 inch / Black
Groupset
SRAM X01Chainset / 170mm / 30T / Black-GXP
SRAM X01 Rear Mech / 11 Speed / Black
SRAM X01 Cassette / 11 Speed / 10-42T
SRAM X0 Trigger Shifter / 11 Speed / Right Hand / Black
SRAM XX1 11 Speed Chain / 118 Links
Avid X0 Trail Brakes / Front / 900mm / 20 Post To Post / Black
Avid X0 Trail Brakes / Rear / 1800mm / 20 Post To IS / Black
Avid HS1 Rotor / 160mm / 6 Bolt
Avid HS1 Rotor / 180mm / 6 Bolt
Avid MMX Matchmaker Clamp / Left
Avid MMX Matchmaker Clamp / Right
Finishing Kit
El Guapo Corto Stem / 35mm / Black
El Guapo Ancho Flat Handlebars / 760mm / Black /
Rockshox Reverb 125mm Drop Seatpost / 31.6mm / 420mm / Black / Left 1500mm
Planet X Sportive Ultra Saddle / CroMo Rail / Black and Grey
On-One Half Bob Lock-On Grips / Black
Wheelset
Pacenti TL28 Rim / 29 Inch / 28mm / 32 Hole
SRAM X0 Hub / Front / 15mm Axle / Black and Red / Without Axle
SRAM X0 Hub / Rear / 12mm Axle / Black and Red / Without Axle
On-One 29" MTB Inner Tube / 2.1-2.2 / Presta / 40mm
On-One Chunky Monkey 29"x2.4" Tyre / Enduro / Folding Bead / Single 50a / Black
On-One Smorgasbord 29"x2.25" Tyre / Trail Extreme / Folding Bead / Dual 60/42a / Black
Brant, will there be an option to move to Shimano brakes from the purchase?
There will.
brant - Member
Groupset
Finishing Kit
Wheelset
On-One Smorgasbord 29"x2.25" Tyre / Trail Extreme / Folding Bead / Dual 60/42a / BlackPOSTED 5 HOURS AGO #
Excellent, now all we need to clear up is when it will "actually" be available
(I think the 'from' in the advert was maybe meant to be in front of the date not the price) 😆
That is a pretty good deal, even the wheels (usual cheap-out point) seem pretty decent, no reverb stealth (nit picking now 😆 )
it's basically a one-bike attack on my On One toy-throwing
looks like a great bike and bang in my line-of-sight for bike spec and ethos. However, should it need a rear triangle "upgrade" ala its sister Nukeproof, previous threads have proved the level of support you'll get is down to the whim of the honchos and whether youre a fanboi.
Looks very good spec for the money does that.
Looks great. Definitely on my (very) short list.
Any idea of weight. I'm a fat knacker so it probably doesn't matter that much. I'll just lose some blubber.
Nice riding by those guys. I'm sure though they could ride nearly as quick on a rigid hardtail. They were naturally quick.
What was that guff in the beginning being cool in a pub and hot tub?
Think about the bike name 😉 pain killers cure for a hang over?
EDIT
It's classic marketing you associate things you want to sell with things that people already like.
So a very goodnight out followed by a ride the next day on a epic bike being a cure for the hangover perfect weekend in some peoples minds...
So can I see the Pomipino video? I missed that one.
It dawned on me the other day that i've ridden one, Ed Oxley's during a skills day. Can't tell you much about it though as it was a couple of sizes too small for me and pretty much was sat on its backside owing to my considerable mass!
No option to bin the Avid brakes from new yet 🙁
Doesn't look like a big wheeler in that vid and that's a good thing. Great riding too.
Looks very interesting and will be on considered list of I ever start riding [s]enough[/s] again to buy a new bike.
Avid Trail brakes are ace.
XT were going in as an option, but we have no stock of them currently.
That vid reminds me of Chainspotting and the Bike (graphically) looks like it's made by Easyjet. I'm tempted though.
It was all going well until I read [s]"Sram" &[/s] "avid"
Any pics of the blue paint option Brant?
This is the only blue pic I have online right now -
Though oddly blue is outselling white right now!
what sort of weight are you expecting on the codiene £2499 build brant?
that videos ace!
and yep dont write off the x0 trails, see my thread a while ago, they are absolutly amazing brakes! not like the avid of old (juicy/elixir etc etc)
A weighed, built, 18in model with spec as on there (reverb, TL28's etc) is 30.06lb
http://www.on-one.co.uk/i/q/CBOOCODX01/on-one-codeine-29-sram-x01-mountain-bike
cool, thats a really price for that build spec, not sure how you've done it but still nice to see somebody 'not ripping us off' for a change!
that video is top class too
Website has the weight at 30lbs, I assume that's a medium?
Edit: Beaten to it by the man himself.
Does absolutely nothing for me personally, but that don't stop it being a lot of bike for £2.5k.
Looks like a good bike at a good price 🙂
Video's entertaining too.
Edit: Problem gone... pre-order in 🙂
Any opportunities coming up to check this bike out Brant?
Nice looking spec for the money. How would the large frame size up for someone 6ft 4? The horizontal top tube and reach figures look reasonable and similar to other brands' xl frames. The website says size large recommended for riders upto 6ft 2.
any chance of a raw finish like the scandal ?
If you can get leg extension with a 20in seat tube, you're good to go.
I'd have said it'll be great.
Colours are blue or white. Both with Orange decals.
Obviously I'm an on one h8er but... **** me that's incredible value. And a lovely blue too. Came for the white, stayed for the blue.
Is the frame not stealth/internal dropper post compatible? Can't see any facility for it...
Brant
Will the Edinburgh store be getting one to get touchy/feely with ?
Nice riding in the video. Looks to be a good deal for the bike too 🙂
No. I wasn't happy with what it was doing to the fatigue test results on the seat tube and didn't want to hold things up longer until I fixed it.
Fair enough that. SO I take it you can extend that to "don't drill a hole in it"!
