Hi all, from some older threads I know replacement bearings can be had from superstar, can anyone point me in the right direction for the top bearing? (the links in those threads are no longer valid)
The bottom should be this: http://www.superstarcomponents.com/en/type-2-headset-bearings-1-5-or-tapered-45x45-degree-x1.htm
Thanks
From my old orders, last I got were...
1 x 1.5" or Taper Headset Bearings 45x45 Degree
1 x Headset Bearings 36x45 Degree Blue Seal - Cane Creek Compatible
The top bearings only came in a pack of two, but provides a spare and think it was same as another bearing I needed.
The bottom 1.5 bearing is the same as my Hope headset bearing, hence I ordered one for that also and perfect fit.
Should be able to get them from any old bearing shop so long as you can match the spec, though Superstar is a good price.
