Small thorn holes i...
[Closed] Small thorn holes in tubeless tyre.
[#11116692]
I decided to give my tubeless a long-overdue overhaul.
Removed both Hans Damps from Stan's rims. Removed worn rim tape, cleaned rims spotless and re-taped. Removed the worst of the old sealant from tyres, noticed 2 thorns in one of the tyres. Pushed them out from the inside, forgot about it.
Tonight I reseated one tyre with soapy water and going hell for leather with a hand pump. Beautiful, all popped into place, will remove valve core and insert sealant later.
Same with second tyre, only half way through did I notice air coming out of the two tiny holes I'd forgotten about. F*CK.
What are my options here? I could remove the tyre again and try to patch the holes but I don't have any kind of repair kit at all and the tyres were hard work to remove/replace. If I carry on and inject the sealant, would that do? The second tyre hasn't seated properly yet (can't achieve enough pressure because of the holes).
I wish I'd just left the thorns in...
Posted : 31/03/2020 11:21 pm
Just chuck some sealant in there. It's what it is there for.
Posted : 31/03/2020 11:23 pm
Posted : 31/03/2020 11:25 pm
Thanks both. Looked up some old threads where people were suggesting repairs but that seemed to be for larger holes/tears.
Posted : 31/03/2020 11:31 pm
Had a Magic Mary once like that. Sealant wouldn't seal it. Ended up using an anchovie.
Posted : 31/03/2020 11:42 pm
Not sure I'd get an anchovy into either hole even if I had one. Not without making the holes a lot bigger. Can barely see one of them.
Posted : 31/03/2020 11:50 pm
Sealant should do it, but it needs to be seated for the sealant to work really. You might get away with giving the non-pumped up tyre a good spin, but if it were me, I'd order a patch kit and patch it, or a new tyre! (Or an anchovy)
Posted : 31/03/2020 11:52 pm
Adding sealant (mixed a bit thicker) did the trick, allowing me to pump to full pressure and seat the beads, no air is escaping from either thorn hole. I don't expect either tyre to stay up overnight but I'll just add some thinner sealant tomorrow and hopefully jobs a good un. Cheers.
Posted : 01/04/2020 1:25 am
