Small Front Lights
[Closed] Small Front Lights
[#11022546]
Looking for something to replace one of these Alpkit front lights that's died.
Must be small, USB rechargeable, waterproofish and not need a bracket that bolts to the bike.
What you commuter types using?
Posted : 26/01/2020 11:58 am
Thanks Simon.
What kind of size are they? There's no dimensions on the link
Forgot to add must fit a 35mm bar.
Posted : 26/01/2020 12:19 pm
Knog.
Posted : 26/01/2020 12:25 pm
The rear I have here is approx 35x28x28mm
I don't have a 35mm bar but the strap looks like it will go around one comfortably.
Posted : 26/01/2020 12:35 pm
Ta.
Posted : 26/01/2020 12:36 pm
Those Trek ones would worry me if being used on their own, they don't look to have much in the way of sideways visibility.
I've got a Magicshine Alty from PlanetX, nice wrap around front lens and held on with a bracketless rubber strap. Battery life is a bit shorter than I'd like but it's plenty bright even on its lower setting.
Posted : 26/01/2020 12:59 pm
Isn't the answer always Exposure? I have Trace and TraceR front and rear.
Posted : 26/01/2020 1:05 pm
New wheel with Dynamo, one of those 'why didn't I do this before?' decisions
Posted : 26/01/2020 1:07 pm
I have mostly Moon branded lights other than a bikehut one and a Brite-R one. The Moon feel the most robust and I commute a number of days a week with them in all weathers.
On my commuter bike I have 2 front lights - a Moon Vortex and a Moon Meteor x Auto. If I had to just have one it would be e Vortex as it has a steady on setting with a brighter flash through it. The other one is either flashing or solid. I tend to commute with the Vortex on that pulse setting and the Meteor on a solid but not highest power setting. Maybe charge once a week or once every other week depending on the length of the route I take / how many times I commute.
Both have solid mounts that work on 35mm bars or road bars and just have a firm rubber fitting (no bolts). You can also leave the mount on and slide the light off the top if you want to take it with you.
Think the Meter is sub £20 and the Vortex is sub £30. They do make a cheaper again Meteor for sub £15 but I’ve not tried that one.
The Vortex does also have a max power of 600 lumens and the Meteor 400 lumens but apart from an unlit bit of tow path and the Bristol / Bath cycle path in the unlit bits I haven’t needed that sort of power for commuting.
Both lights are usb cable rechargeable.
Posted : 26/01/2020 2:02 pm
https://www.gooutdoors.co.uk/15905165/moonlights-meteor-c1-rechargeable-front-bike-light-15905165
Any good, or too big?
70mm long x 40mm wide and surprisingly powerful. I got one for my boy’s bike at Xmas. Good bit of kit for the money 👍
Posted : 26/01/2020 2:11 pm
M-Tigersports CT09CT09 front
on bars
Waterproof
Posted : 26/01/2020 2:58 pm
I haven’t used one of those myself but they had it in the shop when I got the meteor auto x and it looked a nice compact little light tbf.
Posted : 26/01/2020 5:35 pm
 kilo
Trace and trace r +1
Posted : 26/01/2020 6:13 pm
Thanks for all the suggestions but I'm really looking for something small like the Alpkit one in the OP.
Anyone got/had a Lezyne strip drive 400?
Posted : 26/01/2020 6:46 pm
I'd say trace. Looks odd in a picture but works well in practice
Ok that's based on owning a trace r
They are about £35 and tiny
https://road.cc/content/review/258307-exposure-trace-daybright
Posted : 26/01/2020 8:19 pm
Already have a trace R for the rear and as great as it has been i'm looking for something that sits on the front of the bar without a bracket as such.
Posted : 26/01/2020 8:24 pm
Ravemen LR500s or 800s
Cutoff beam. Can also operate from a USB to extend runtimes for longer rides. Can also add a wired remote switch for less than a fiver.
Also the Ravemen CR700 for another small torch style with similar features. All these lights have a mount that is a rubber strap-hook thing and also quick release.
Seriously recommend checking out the reviews and the beam patterns
Posted : 26/01/2020 9:02 pm
I have a cat eye volt 200 something or other.
Surprisingly good value for money imo.
Used as back up for my commute , v useful on flash mode in city traffic.
Rubber band bracket , usb charger and decent battery life . I think they do a 400 & 600 version which cost more and are larger.
Posted : 26/01/2020 10:04 pm
I have a Lezyne strip drive that died, customer service was pretty poor - 'sealed unit' blah blah. I've taken it apart and have ordered a new battery from china in the hope of fixing it
My little alpkit tau set is working great on my brompton, very pleased with them
COB lights are good, they have a wide field of view so are very visible. The bright lights that are focussed are annoying, OK from an angle but from the wrong point of view they're blinding
Posted : 27/01/2020 12:20 pm
For commuting? Get a STVZO one, lezyne and cateye both do them now.
Posted : 27/01/2020 12:46 pm
