SLX sticky lever
[Closed] SLX sticky lever
 pnik
[#1978359]
My rear brake lever has started sticking, in that there is some initial resistance to braking, in the lever I think, with more pressure you go past the point and it works. It comes and goes too, but always that lever, when you get past the resistance there is a sort of clicking sound. bit wierd and a little worrying occassionally.
Any thoughts
Posted : 10/09/2010 2:45 pm
Not too sure if you can [s]srtip[/s] strip SLX brakes?
Posted : 10/09/2010 3:18 pm
Seen this a few times, usually a caliper piston sticking.Another possible cause could be if the reach has been adjusted too far, causing the lever to go "over centre".
Posted : 10/09/2010 7:09 pm
