SLX hanger bolt loo...
[Closed] SLX hanger bolt loosening ?
[#901123]
I fitted a new SLX rear mech for the first time about 5 months ago. Some while later I noticed it wobbling and found the bolt that holds it to the hanger was loose, so I told myself I was a limp wristed numpty and tightened it up. I've just put my bike together and found it loose again, though I know I did it up as tight as seemed sensible - anyone else had one work loose ?
Posted : 27/09/2009 11:39 am
never had anything work loose
decent torque wrench/manual
loctite torqseal etc - thread locking products.
cut, sprung washer *depends on fitting and may not be suitable
Tip - get an old nut and bolt (you don't need and of no use), and big spanner and keep tightening it till you get that sickening feel when it suddenly goes from v hard to turn to free rotation, remember that feeling before applying brute force and ignorance.
Posted : 27/09/2009 11:56 am
done that, been there 🙂
I've fitted probably 20 mechs to date without any of them loosening, but this is a new type and slightly different, though presumably Shimano would have fitted a washer if it was needed.
Posted : 27/09/2009 12:00 pm
how old's your frame simon - maybe threads are worn ?
replaceable hanger ?
Posted : 27/09/2009 12:13 pm
Hmmm, my XT loosened off as well, only happened once, but I've kept an eye on it ever since. I don't think it's actually a problem if you catch it, but it's a bit annoying. Bit of locktite?
Posted : 27/09/2009 12:17 pm
the hanger is about 6 months old.
What's interesting is that this type is actually easier to tighten, as it's not coaxial with the tension spring, which on the SLX is displaced to the rear on a short bracket.
Posted : 27/09/2009 12:22 pm
just threadlock it?
Posted : 27/09/2009 12:26 pm
just threadlock it?
well I might, if I can find some, but none of my unthreadlocked bolts undo themselves...
Posted : 27/09/2009 12:34 pm
it shouldn't, but it's probably more hassle than it's worth to find out exactly why it is.
Posted : 27/09/2009 12:35 pm
if you need to use some threadlock simon let me know i've got some i can lend you a bit
Posted : 27/09/2009 6:32 pm
cheers :o)
Posted : 27/09/2009 6:34 pm
