SLX Front mechs - T...
[Closed] SLX Front mechs - Too many choices!
[#4785560]
I need to buy a new mech to fit my new Cotic Soul. I'm running 3x9 speed chainset at the moment - Truvativ Blaze. I plan to move to a SLX 2x10 chainset in the summer, but cannot afford to do it at the moment.
Looking at the SLX front mechs on CRC. There seem to be a million different options to choice from. I a bit dubious about much difference there really is:
1) Is there any technical reason one would choose a conventional mech over the standard? I can see the obvious reason if it won't fit the frame etc. on full sus. But cannot see any other reason other than aesthetics?
2) Is there any real difference between the 2x10 mech and the 3x10 mech? I'm thinking I can just wind the stop screw in if I use it on a 2x chainset?
3) Any reason why I cannot use a LH shifter from the 9spd range on a 10x front mech? I know the rear mech isn't compatible because of the actuation ration. I've not heard of changes on the front mech actuation.
I've had a look on the Shimano website, but as usual only half the info is there.
Posted : 22/01/2013 11:46 pm
I was thinking this exact same thing the other day! I've previously been running a 3x front mech and shifter with 2x chainrings and its not been a problem, my Bfe hopefully arrives this week so needed a new front mech, think I just ordered a 2x9 one in the hope it will still work with my 3x shifters but no idea!
In my head I'm imagining they will all work the same but I think the 2x mechs are slightly more compact as they dnt need to reach the big ring.
Posted : 22/01/2013 11:56 pm
2x mechs have shorter bit that does de-railing. The clamp position is not critical on a conventional frame, but FS & 29ers where space is an issue it is.
Posted : 23/01/2013 12:21 am
Oh & top swing ones by virtue of being tucked down lower collect more muck
Posted : 23/01/2013 12:22 am
Haven't had a close look at the 10 speed stuff but the 2x9 SLX shifter was the lightest mtb mech Shimano did at the time, might be the same's still true. It also worked better than a 3x9 one- custom shaped cage.
