SLX Crankset
[Closed] SLX Crankset
[#356980]
Does anyone know if anyone has the SLX Double and Bash crankset in stock? 175 mm version?
Or do I just go for the triple and fit my existing bash?
Decisions!
P
Posted : 03/03/2009 11:14 am
I'd hold out for the double and bash, you get the more sensible 22 / 36 option. Merlin best on price last night when I looked, but not sure on stocks.
Posted : 03/03/2009 11:16 am
That's my quandry- I've been happy enough one by nine with a 32...
Posted : 03/03/2009 11:21 am
what about getting the 22/36 and a road cassette then, that way you will get better spacing between gears, less weight and can use a shorter mech thats out of the way a bit more.
Posted : 03/03/2009 11:23 am
Problem is no one has the 22/36 in stock.
It's going on a 29er too, so I'd rather stick with a big cassette.
Posted : 03/03/2009 11:42 am
The bash ring it comes with is pretty heavy, so if you've got a nice alloy one lying around you could save some weight. You get the fancy composite chain ring on the triple version too.
Posted : 03/03/2009 11:45 am
I'd just get the triple set up and fit your own bashring. You could put the other rings into stock as spares or could sell them. If you really need a 36t ring then get a cheapy Deore one that will last longer anyway.
Posted : 03/03/2009 11:46 am
Isn't the bash ring version beefed up in other areas too? Heavier gauge axle? Pedal Thread inserts? I could be wrong but I seem to remember something like that......
Posted : 03/03/2009 11:55 am
The double does indeed have pedal thread inserts.
Posted : 03/03/2009 12:01 pm
Does that mean the triple doesn't?
Surely it's just the chainring set-up that differs?
Posted : 03/03/2009 12:11 pm
Cheers guys- gone for the triple...
Posted : 03/03/2009 12:12 pm
The triple does not have inserts. I have checked.
Posted : 03/03/2009 12:34 pm
[i]"Does that mean the triple doesn't?
Surely it's just the chainring set-up that differs? "[/i]
Nope. The SLX bash has steel pedal thread inserts and a steel axle for extras strength/stiffness. The 36/22T rings are (softer than steel) aluminium. Weighs about 1kg
The SLX triple doesn't have the steel axle or pedal threads. The middle ring is (hard wearing)steel/composite(to make lighter) too. All in is 889g
Merlin have a couple of 36/24T truvtiv HTII style cranksets that weigh AND cost less than the SLX bash crankset
Add insult to injury - I've got a Truvativ Stylo AM 2.2 (2009) with
24/36T going on ebay for 70 squid having been "given" a M665 !!
Posted : 03/03/2009 12:42 pm
Thanks for all the info guys- not too worried about the inserts, and I wouldn't go for a Truvativ crank again.
Posted : 03/03/2009 12:48 pm
excuse my muppet-ness, but would this fit a 68mm BB shell, or is that not even an issue with external BBs?
Posted : 03/03/2009 12:55 pm
external BBs come with spacers to allow to run 68mm shell, 73mm shell and/or with a bottom bracketed front mech or chain device (not both on a 73mm shell though)
Posted : 03/03/2009 1:03 pm
righto, cheers.
hmm, tempted by the truvativ stylo now as this would fit the bill nicely for taming my stiffee somewhat (currently 1x8, 38T DH ring with e.13 fitted but i want to ride it up a bit as well now!)
hmmm...
