SLX cassettes- carr...
[Closed] SLX cassettes- carrier like XT?
[#3428212]
As above really- do SLX cassettes come with the alloy carrier like XTs, so they won't mash up my Pro IIs?
Posted : 05/12/2011 2:07 pm
 nbt
yes, I ordered one last week for that very reason. Ribble, £36.
Posted : 05/12/2011 2:09 pm
yes and no.
they have a carrier, but it is for less of the sprockets.
Should be fine on pro2, I find it is the larger sprockets that have the torque to eat the freehub, and they are the ones on a spider.
Dave
Posted : 05/12/2011 2:10 pm
Ta nbt
As above, 1/2 carrier not full - I used on my Pro3, slight traces of burring after 12 months but by no means mashed and didn't affect cassette removal.
Posted : 05/12/2011 2:41 pm
If you'd consider SRAM then at least PG980 also has a simialar 3 biggest type carrier and virtually the same weight as SLX (pg990 i think has 5 like XT). Not sure what the 10spd SRAMs are like though
Posted : 05/12/2011 2:42 pm
The small teeth will still rip up the freehub, but then XT does that as well.
If you've got an old XT cassette, keep the lockring, quite a bit of the weight difference between SLX and XT is in the ring surprisingly.
Posted : 05/12/2011 7:26 pm
If its 10spd as well, there is virtually no weight difference between the SLX & XT cassettes. For some reason all Shimano 10spd cassettes are boat anchors.
Posted : 05/12/2011 8:52 pm
