Slx brakes... Cheap...
[Closed] Slx brakes... Cheapest where ?
[#8404715]
Looking for some current slx brakes and cheapest i can find is bike discount de @ 130 ish.
Is there anywhere else doing them cheaper ?
Cheers.
Posted : 18/03/2017 12:33 pm
 Euro
Just got some (delivered today but im in work) for £109 from Merlin. That doesn't include rotors though
Posted : 18/03/2017 1:10 pm
My previous psa about brakes from high on bikes should be ignored.
Even though the ad said right front they are in fact left front.
Posted : 18/03/2017 1:14 pm
Euro ?? How ??
Is that the new models ?
Posted : 18/03/2017 1:21 pm
By looks of things he's referring to the m675 models, the m7000's are £160
Posted : 18/03/2017 1:43 pm
Not sure if it helps but I've just taken a punt on a set of m8000 xt brakes from alpine trek for £118 (£113 after their £5 off for first order discount code). Not arrived yet but was the cheapest I could find and reviews seem ok (they used to be called bergfreude).
Posted : 18/03/2017 8:37 pm
Bentleywood
Thanks for that.
What does it mean when it gives you the option of vr or HR ?
Posted : 18/03/2017 8:50 pm
VR front 1000mm hose
HR rear 1700mm hose
Leitungslänge: 1000 mm (VR) / 1700 mm (HR)
Although it doesn't clarify the hose lengths on alpine trek.. But above is normally the hose lengths..so does the low price include the hoses?
Posted : 18/03/2017 8:59 pm
I'm guessing so as you can chose between each.
Posted : 18/03/2017 9:14 pm
Will report back when they arrive but I needed a pair so hopefully the acronym means front and rear, it translates as that on the action sports website... and the hoses are the right length assuming they are supplied!
Posted : 18/03/2017 9:29 pm
Here we are, Hinterradbremse is a rear brake and Vorderradbremse is a front according to google.
Posted : 18/03/2017 9:41 pm
Remember that the calipers will be on the "wrong" levers as they'll be for Euro fitment. Should be an easy swap over though. Being careful means you'll likely not need to bleed them.
Posted : 18/03/2017 9:43 pm
Had my first ride last week on a pair of merlin m675. They came the 'wrong' way round and it was fairly easy to swap over. Just be careful not to knock the hoses when disconnected. And do the swap with the levers on the bars.
Posted : 18/03/2017 10:19 pm
Cheers all.
Took a punt on those Xt mentioned above.
Not fussed about swapping hoses over as have done it before and the rear one will need feeding through the frame anyway.
Posted : 19/03/2017 9:20 am
We'll mine have turned up today and I'm very pleased. Full retail packaging, finned pads and spare olive etc. Just need to swap the levers round now and feed the rear hose through my new clockwork frame...
Only slight niggle was that there was no dispatch email etc so I chased this morning (to which I got a quick response) as they simultaneously arrived in the post.
Posted : 20/03/2017 7:06 pm
Good stuff.
How long did they take to come mate. Mine have been dispatched today.
Are the hoses full length ?
Posted : 20/03/2017 8:06 pm
 Euro
Euro ?? How ??
2016 i think. Arrived and fitted today. Couldn't be arsed swapping the levers over so i'll be going euro 😀 It's only since starting mtb 10 years ago i've run brakes the normal? way. Always rode bmx with right/back so hopefully the transition wont be a painful one. Find out tomorrow
Posted : 20/03/2017 10:32 pm
No longer listed on AlpineTreks website..
Posted : 20/03/2017 10:39 pm
Merlin £127.99 for the m7000 slx set
https://www.merlincycles.com/shimano-slx-m7000-front-and-rear-disc-brake-set-standard-pads-100480.html
Posted : 21/03/2017 7:32 am
For me (as a Euro buyer) - bikecomponents.de has a cheaper price at 139 euro versus 149 from Merlin but maybe that small difference isn't worth the bother...
They also have XT 8000 for just 175 euro
Posted : 21/03/2017 8:30 am
To save hours of reading, what's the difference between the m7000 and the M675 SLX brakes ?
When the Mrs gets paid tomorrow I'm pulling the trigger and replacing a shot pair of Hope Mini on the Inbred.
Posted : 22/03/2017 3:48 pm
Does it really take hours to read the 20 posts above yours?
Next you'll be asking us to fit them for you..
Posted : 22/03/2017 10:53 pm
Wonderful reply, thanks.
Reminds me why I don't post here.
post above state Price difference, yup, compare against XT, yup.
Actual performance/justification between two version of the SLX? Where?
Posted : 23/03/2017 10:34 pm
Sorry for not replying earlier.
Difference between the slx models is a more inline master cylinder I believe.
A lot of people say they can't really tell the difference in performance to be honest.
Oh and that's a bit of a **** reply from goldigger tbh
Posted : 23/03/2017 10:43 pm
Renton, I am running xT's on the horsethief, super after a bleed and uber race matrix fitted. Really enjoying Salsa.
Posted : 23/03/2017 10:47 pm
Hey up Wally.
Glad you are enjoying the Horsethief.
Get some pics of it mate.
Posted : 23/03/2017 10:52 pm
Thanks for the reply Renton.
Other info I've dug up since I got home earlier than expected tonight is:
"The bar clamp is i-Spec II compatible"
"the I-Spec-II system on M7000 will ONLY allow Shimano 11-sp. shifters to be fitted."
"M7000 is a mild evolution of M675. The biggest operating difference between the two is that M7000 has considerably better modulation"
Posted : 23/03/2017 11:14 pm
sorry I was just taking the p@ss
I've got some m675 brakes on my dude, performance wise there's not a lot of difference between them and the m785 that I have on my Anthem.
Calipers are virtually identical apart from a split pin rather than a Bolt to hold the pads in place.
Levers are just missing the free stroke adjustment.
I believe the M7000 come fitted with resin pads rather than sintered. As above the master cylinder is more integrated which makes them more slimline.
I'm tempted to sell my m675 brakes and replace them with XT to match the XT 11 speed. There about 6 weeks old.
Weights lever+caliper+hose
M675 287g
M7000 271g
Posted : 23/03/2017 11:58 pm
Sorry with a 1000mm hose weights are:
M675 294g
M7000 271g
Posted : 24/03/2017 12:15 am
That's now 2 shops that have sent me a front left instead of the advertised front right.
Why someone would import them into the country I don't know.
Posted : 24/03/2017 2:36 pm
