Slotted disc mount
[Closed] Slotted disc mount
[#1742761]
Looking to change something on a frame and need a slotted caliper mount for a rear stay, wher can I get one from?
Help
Posted : 26/06/2010 6:57 pm
if you have vertical drop outs then the location of any IS calliper mounts will be to IS specification so if you were to "move" the location of the calliper it may not align correctly with it's associated rotor. If you want to change the rotor diameter then you need an appropriate calliper adaptor.
If you have horizontal drop outs but fixed IS calliper mounts then that is a bad frame design.
EDIT: or do you mean you want to remove an old IS mount and weld a new one on your old frame?
Posted : 26/06/2010 7:02 pm
No I need slotted disc mounts as the frame has horizontal dropout this way caliper alignment will be easier
Posted : 26/06/2010 7:46 pm
These are designed for retro fitting to horizontal dropouts
I've got one for my SS but haven't fitted it yet, Still running Vs.
Posted : 26/06/2010 7:51 pm
 Sven
Nick, could you link to these adapters, please, couldn't find them on the web (pic seems to be from the/a Raleigh website).
Posted : 26/06/2010 8:40 pm
These work very well .
in stock at raliegh dealers,made by Quadbrakes.
been running one on a Surly for 2-3 years.
Posted : 26/06/2010 9:50 pm
I got mine 2nd hand so can't help, sorry. Sounds promising above, though.
Posted : 26/06/2010 10:48 pm
Found one at last
$20 delivered
Posted : 14/07/2010 10:11 pm
