Slippy seatpost - c...
[Closed] Slippy seatpost - carbon paste stuff?
[#6311302]
I have a Gravity Dropper post in an Genesis 853 frame, with a Thompson clamp.
If I have the clamp tight enough to stop the post slipping down, the dropper doesn't return properly. If I loosen it enough to allow the dropper to work properly, the post slips down the seat tube. Grr.
Is carbon assembly paste the stuff I need to give the seatpost a bit of grip in the seat tube?
Posted : 02/07/2014 11:03 am
Yup.
Posted : 02/07/2014 11:04 am
 tomd
Hylomar blue non setting gasketing compound. Can be had for £2.99 for pretty much a lifetime supply. Works a treat.
Posted : 02/07/2014 11:06 am
Have used assembly paste even when there isn't a problem. Clamp barely needs tightening. Excellent stuff
Posted : 02/07/2014 11:10 am
If I bought a tube of it, where else would I use it on the bike? The only other thing I grease before assembly is a very light smear on the steerer before I put the stem on.
Posted : 02/07/2014 11:13 am
Bar/stem.
Posted : 02/07/2014 11:15 am
Right. A tube's going to last a while, isn't it...
Posted : 02/07/2014 11:16 am
No need for a whole tube http://www.wiggle.co.uk/ritchey-liquid-torque/
I would see if you can get some off a friend. You need about 20p's worth out of a £8 tube.
Posted : 02/07/2014 11:17 am
 tomd
I used it to hold the crank on my city rat bike when the bolt fell out. It's a fraction of the price of carbon assembly paste, which is its main selling point.
Or if you have any pumps to assemble, you could use it there.
Posted : 02/07/2014 11:21 am
