Any ideas to stop it creeping down. It's alu in an alu frame.
Posted : 26/07/2013 8:42 am
Degrease the tube & post then use carbon assembly paste on it instead of grease.
you won't need to clamp it anywhere near as tightly either.
This sorted out a mate's post on his EX8.
Posted : 26/07/2013 8:44 am
Is it a QR clamp? In fact no matter if it is or it isnt, lube the clamp bolt, & clamps interface with the seatube.
Posted : 26/07/2013 8:50 am
Ordered some carbon stuff. Have torqued bolt to specified amount to reluctant to whack it right up.
Posted : 26/07/2013 8:56 am
No one said whack it right up, the lube on the clamp & bolt will mean the clamping force onto the seat tube will go up because its allowing the clamp to work with less friction in other areas.
Posted : 26/07/2013 9:14 am
