slight wobble in ne...
[Closed] slight wobble in new tyre
[#10770077]
Its a brand new Magic Mary 2.35 being run tubeless. The rim is true. Ive checked the bead / rim seating and rode around with it at low pressure, deflated and soaped bead, reseated it. Its 100% in the bead. But there is still a definite wobble, but only a minor 5mm deflection.
Is this likely to settle down after a few rides? I really can't be bothered to swap it out and send back to Chain Reaction.
Posted : 16/08/2019 4:44 pm
I've had this with Schwalbe tyres. The rear Racing Ralph on my Giant Anthem came like this. It doesn't affect the ride but I'd send yours back for a replacement if you're not happy.
Posted : 16/08/2019 5:21 pm
 Yak
It won't settle down. It's wonky. Send it back or put up with it. It's like 30%* of schwalbes are made on a Friday afternoon after a liquid lunch.
* of my limited sample
Posted : 16/08/2019 5:55 pm
If it doesn't affect the ride then i'll just put up with it. Ive slung the box it came in and the tyre is full of sealant. Plus i'm lazy.
Posted : 16/08/2019 5:59 pm
I have this same problem which I think is due to my own stupidity of ignoring my hardtail for too long and it sitting on flat tyres. I just swapped the DHF 2.5 for the DHR2 2.4 I’d previously had on the back. That one isn’t quite as bad but there’s still a sudden 3-4mm of wobble at one point, which I guess is where the weight was on the flat tyre.
I’m taking the bike on holiday on Monday. Can I ignore it or do I need a new front tyre? Thankfully the new DHR2 2.3 on the back is all good!
Posted : 17/08/2019 10:31 am
