Is there any point?
I have a FS bike with a 68deg unsagged head angle. I'd like it to be slacker really but don't want/can't afford longer forks.
On one sell these slacksets that supposedly take the head angle out by 1 degree.
The head tube is 120mm long and standard 1.125, so they have one that fits, but will it make a noticeable difference to the head angle? I suspect not, has anyone fitted one to a similar frame and noticed a difference when riding?
What a stupid question
I'm kind of with GW on this one. It'll make a one(-ish) degree difference, which is a difference. Whether you'll feel it or not is another matter. I assume when you say you want to make it slacker, you mean slacker by more than 1 degree?
Increasing fork length by 20mm, which I'd guess is round about the biggest jump you could make, will also give roughly 1 degree. The difference between the two methods is that the headset will marginally lower you BB and the longer forks will raise it.
You could combine the headset with offset shock bushes to increase the amount of slackness...
Cheers for that warpcow, I guess the reason I asked was cos I couldn't see the point of these slacksets anyway, maybe if you have a short fat headtube and can change the angle by 2 degrees or more it might be worth it.
I wonder if they have actually sold any for standard head tubes?
And GW thanks again for your as ever charming and helpful response. you really are a delightful human being. 🙄
My mate fitted one to his bike, taking it from about 68 down to around 67. He has a set of offset bushings ordered to, but reckoned the Slackset made a noticeable difference to the ride so far.
I'm peckish, I'd like a biscuit, there are biscuits in my cupboard. But is there any point?
I know, I'll ask on STW 🙄
Depends if they are chocolate or plain?
Got both, which would you prefer I have sv?
As you've dared ask a question about MTBs on an MTB website, there are also other headset options-
[url] http://www.workscomponents.co.uk/index.asp [/url]
have a works components one on my rigid hummer does feel quite different
cheers for that link scruff, very helpful
I think I'm correct in saying that the On One headset is just a rebranded Works one(?). There's also an Israeli guy who can custom-make them for about the same price (might be able to eke out a slightly bigger change), but I forget his name. He's on mtbr a lot.
Hmm I bought a rear mech hanger from an israeli off ebay a few years ago I guess its probably him.
I'd wager it will make a noticeable difference.
I have a 1 degree Works Components on my hardtail (traditional 1 1/8"). Makes a difference IMO.
[url] http://www.workscomponents.co.uk/works-components---10-degree-ec34---traditional-1-18-fitment-6-p.asp [/url]
The way we write "On-One Slackset by Works Components" is a bit of a giveaway.
http://www.on-one.co.uk/i/q/HSWCSLS/on_one_slackset_headset_by_works_components_for_carbon_456
