Slack chain & B...
[Closed] Slack chain & B screw?
[#6206241]
Just gone from 1x10 to 2x10 on my spitty for a couple of lakes rides I've got planned.
Chain length is correct but when on small/small and the next couple of gears up the cassette the chain is slack. If I wind the b screw in all the way the slack is removed. When the shock is fully compressed and on big/big there is still room for the mech to move so would I be right in saying this should be ok?
With the screw wound all the way in shifting is still smooth.
I know people will say don't run small/small etc but I always thought one of the advantages of x2 and x1 was that you could use all of the cassette? Running 36/24 upfront with a 11/36 cassette. Rear mech is a GS xt clutch. Think I'm 1 'cog' over its capacity?
Am I ok leaving the b screw wound all the way in or will this cause problems elsewhere?
Thanks.
Posted : 21/05/2014 12:56 am
In 2x I'd normally not use small x small still. If the rest is working well stick with the set-up and just avoid the crossed gears.
Posted : 21/05/2014 1:09 am
Wouldn't purposely cross gear but the last thing on my mind on long climbs are my gears! Will have to start paying more attention.
Will give it a run out and see how it goes, thanks!
Posted : 22/05/2014 8:27 am
