Skills Coaching req...
Skills Coaching required: How to avoid hitting rocks?
Main issue seem to be needing to retension spokes every so often
my Roval experience matches yours. Rear just would not stay true and tensioned. Pulled a couple of nipples over the 3 years I owned them, but it got to the point where I was have to tension the rear after every ride. Not sure it the rim is too stiff, or that 28 spokes isn’t sufficient…git bored, replaced it in the end
Posted : 05/07/2022 12:15 pm
 mert
TBH, i've got what looks like a bigger gouge than that in my trispoke from a dickhead outside a TT HQ.
If it's just the top layer (which is what it looks like) just cut the loose bit off, sand it down a bit and add a blob of epoxy, then sand that down when it's hardened.
Posted : 05/07/2022 12:51 pm
The warranty should cover defects in design and materials as well as manufacturing. If Carbon Fibre isn’t suitable for making all mountain wheels ( as many people above seem to be saying) then they shouldn’t sell them. Rock strikes are an integral part of off road biking.
But strictly speaking you got home and didn't explode...
It's pretty simple in that carbon fibre is less hard than most rocks .. if you are a sponsored rider, it gets you down/home (EWS you hope through the series) and sponsor gives you a new wheel.
As for car comparison... concrete bollards are part and parcel of roads... if you reversed into one then you hope you can get home OK.. but the bumper might be cosmetically damaged or even need replacing...
I do completely the marketing is misleading... as opposed to the warranty as reading a 16 page T&C in 6pt grey on a grey background when buying some wheels (or whatever) is obviously trying to slip it under the radar.
SC did the whole carbon frame video the the sledge hammer... I'd like to see them do the same with a gentle tap with a ice pick for example...
Posted : 05/07/2022 1:35 pm
Page 2 / 2
