Singular Puffin max...
[Closed] Singular Puffin maximum rear tyre clearance.
[#6584994]
Afternoon all.
I am in the process of building up my Singular Puffin and have gotten to the stage of choosing some tyres. As I'd like to maximise my fatness, so to speak, I was wondering, what is the widest tyres you guys are running on the rear of your Singular Puffins? If it helps, I am using 80mm rims and a 1x10 drivetrain.
Posted : 26/10/2014 4:32 pm
I think I saw somewhere that 4.8" rear as the maximum. It might have been on one of the blog posts.
Posted : 26/10/2014 5:09 pm
Sam said a 4.8" tyre on a 80mm rim will fit in the back.
Frame clearance for 26×4.7? tyres (Surly Big Fat Larry on 80mm rim) Fork clearance for 26×4.8? tyre (Surly Lou on 100mm rim)
A Nate on a Marge Lite fill the rear nicely but I would be curious to see as bigger tyre in the back either on a ML or a RD.
Posted : 26/10/2014 6:02 pm
Plenty of space for a Nate or Floater on a Rolling Darryl
Posted : 26/10/2014 6:08 pm
Thanks for the responses so far guys. I guess I am secretly hoping that I can squeeze a Lou in the rear. According to the Surly Tire Geometry chart it states that there is an 11mm difference between the BFL and the Lou mounted on an 82mm rim. Only 5.5mm per side I know, but it could make all the difference as I don't know how tight the BFL is in the first place.
Trouble is, it could be a rather costly mistake only to find out they don't fit. 😀
Posted : 26/10/2014 6:26 pm
Your more likely to be able to fit a ground control in than a Lou
Posted : 26/10/2014 7:00 pm
I'd buy a Bud, and try that in the rear, if it fits, buy another for the front its what the Surly guys run as the tyre rolls a lot better than Lou.
I run Bud and Lou on the moonlander but would happily run two Buds.
Posted : 26/10/2014 7:44 pm
Hmm thanks gibbonarms, not a bad idea. What are the implications of having a larger circumference wheel at the front if it doesn't fit the rear?
Posted : 27/10/2014 1:42 pm
Bud is 13mm taller than Nate so will raise the front end slightly, full specs here:
[url= http://surlybikes.com/blog/post/how_fat_can_we_go ]http://surlybikes.com/blog/post/how_fat_can_we_go[/url]
Posted : 27/10/2014 2:25 pm
Probably no discernible difference then I would guess. Many thanks once again.
Posted : 27/10/2014 5:41 pm
If you ride sticky gloppy mud then your likely to run short of clearance even if you have sufficient clearance in dry conditions
Posted : 27/10/2014 6:31 pm
Yep, that's a good point.
Posted : 27/10/2014 9:58 pm
 Sam
Thomas in Germany is running a Bud on a Marge Lite even with a double chainring! I saw it in person and it is VERY tight.
[img] ?oh=f1fa0039384c94d7fa842cfbc9c305cf&oe=54E4C561[/img]
Laurent in France has a Bud on a Rolling Darryl and that is even tighter.
[img] ?oh=fedb300e72dc610883549505c6740e4d&oe=54AC93C4[/img]
T1000 makes a good point - if you are riding in mud then you want to have more clearance than either offers. I'd go with a BFL if you want volume, or a Nate if you want knobbiness.
Posted : 29/10/2014 11:53 am
I think a specialized ground Control would make a good compromise sitting somewhere inbetween Nate and Bud in volume
Posted : 29/10/2014 12:53 pm
Wow! That is tight. Thanks chaps, think that has answered my question once and for all.
Posted : 29/10/2014 1:55 pm
