And if so, how tall are you and what's you're inside leg?
cheers chaps 🙂
anyone?
seriously, no-one rides a small Peregrine?
what about looking on singular website/emailing sam/emailing the seller?
yep, have done such things... website doesn't really say what size suits whom, seller is a little shorter than me but has around the same inside leg... I'm just looking for a bit more info from current owners of small Peregrines is all, hope it doesn't offend 😉
Right, this won't directly answer your question, but you might be able to get a start from it, comparing the large and small frame sizing.
That said, it might well turn out to be a load of irrelevant cack instead.
I'm 6ft with an inside leg of close to 33inches.
I ride a large Peregrine - on 175mm cranks, and a 90mm/+5'stem (that is to say it's 'upwards'). The seatpost has a 25-30mm offset.
Hi had a small - 5'9" (& a bit). No idea what my inside leg is - 32-32 Levis if that helps.
I'm 5'8" or thereabouts... I'm fairly sure a small will be fine, but never hurts to ask for opinions 🙂
ah well... doesn't matter in the end, I missed out on the one in the classifieds 😥
