Singlespeeders - Ho...
[Closed] Singlespeeders - Horizontal Dropouts / What Chain Tugs?
[#3373511]
Just wondering what people run? Want to get something ordered today.
Or, do people running horizontal dropouts run chain tugs at all? Is that do-able?
Dave
Posted : 21/11/2011 10:50 am
use a dmr chaintug on somethign like this;
not on somethign like this;
Posted : 21/11/2011 10:52 am
Track end or horizontal dropout?
Posted : 21/11/2011 10:54 am
 D0NK
I use an ebay dmr copy heavily modified. c456 is a bit of an unusual shape at the drop out, OO don't seem to do a 100% compatible one, had to do a lot of filing to get mine to fit and actually give a decent amount of useable "travel"
If you use a shimano QR done up well ***tard tight it [i]might[/i] hold OK.
Posted : 21/11/2011 10:57 am
as per D0nk on the carbon 456 - you have to grind a lot off a dmr chain tug to get it to fit and allow a range of adjustment once in place.
Posted : 21/11/2011 11:00 am
The surly one I use has two holes you can use so you get a much longer range of movement (i.e. almost the entire slot) for a given amount of bolt length.
Posted : 21/11/2011 11:01 am
if you're running horizontal drops you can use the double bolt style of chain tensioner - just need to break out the grinder.
Posted : 21/11/2011 11:49 am
