Singlespeed woes - ...
[Closed] Singlespeed woes - chain skipping
 dot
[#3987999]
Fitted a 14 cog to my ye olde commuter last night (38:16 was waaay too spinny) but chain now skips under load.
Chain has has some use but not stretched beyond 0.75%, I'm using a surly type tensioner (the cheap copy). and chain still looks quite tensioned. Any ideas as to why it is skipping? Would removing couple of links fix it?
ta
Posted : 18/05/2012 2:11 pm
Switching cogs does that.
Increase the tension on the tensioners to max. If that doesn't fix it, reduce the tension to lowest and remove a link, then slowly increase the tension until it does.
Posted : 18/05/2012 2:13 pm
new chain time...
Posted : 18/05/2012 2:16 pm
had exactly this when i fitted a new chain to an old cog - new cog fixed it....
Posted : 18/05/2012 2:21 pm
 dot
Cheers for replies, 2 links removed from chain fixed it 🙂
Posted : 19/05/2012 3:32 pm
