singlespeed wheel a...
[Closed] singlespeed wheel advice
[#5720194]
sorry - had a quick google but being a bit lazy so just thought i'd ask here anyway.
Have bought a Genesis io-iD frame. Would like to build it up as a singlespeed crosser so was going to just get geared 29er disc wheelset and use a spacer kit rather than buy a singlespeed specific wheelset.
Question is would it be fairly easy to swap out the disc for a velosolo bolt on cog if I ever felt the need to play about on it fixed and do away with the rear brake or am I being thick thinking that would work?
Posted : 25/11/2013 1:12 pm
double check a 29er wheel will fit because its a 26er frame. they probably will but worth a check.
And yes that should work fine.
Posted : 25/11/2013 1:14 pm
would work no problems, bu you may need washers to make sure the chainline is right,
All explained on the velosolo site, I've done it and it works a treat.
Posted : 25/11/2013 1:15 pm
cheers 🙂
Posted : 25/11/2013 1:27 pm
The io-iD is a 26er. Are you swapping the forks too? I run mine SS with standard Hope/Stan's Crest wheels and Onza freehub spacers. I can only find one 26" cyclocross tyre - anyone seen anything other than Conti CX-pro?
EDIT: just measured. 26" and 2.2 Nobby Nics are 67cm. The seatstay bridge has 3 cm of clearance. 700c with a 23c tyre is 68 cm. So if you add a 33c tyre with nobblies, you should retain 1cm of rear mud clearance. This will raise the BB by 1 cm and you'll need a 700c fork. Just given me a reason to "invest" in a new wheelset 😉
Posted : 25/11/2013 2:08 pm
hey mate. I had 26" Schwalbe Smart Sams a couple of years ago. Planet X sold them. Might be worth checking there?
Just decided to stick with 26". Bought a rigid fork 44.5cm adjusted for 4" travel forks.
Means I can use existing wheels as I probably should be keeping the cost down a bit 😉
Will still buy a 6 bolt adapter to keep fixed options open 🙂
Posted : 25/11/2013 4:14 pm
Oodle of room on an iO for 29er/700c wheels.
IIRC I had 42mm tyres fitted with room.
This build was built with a 420mm fork too.
Wheel is sitting in its "closest" posistion:
Edit ... too late - must get quicker at finding pics 😳
Posted : 25/11/2013 4:32 pm
