Looking for a silver 32t 5 bolt chainring for a singlespeed project, it's to go on some old shimano crank arms. Tried all the usual websites but struggling on the 5 bolt. Any ideas... cheaper the better...
hello,
i stil have a used one from my clearout a while back.
[url= http://www.singletrackworld.com/forum/topic/fslarge-clearout-pics-haggling-opportunity-all-must-go-ot-wetsuitmp3 ]Any good to you?[/url]
Surly?
I've got 5 bolt CD SS SS rings in 30T and 34T. Should be widely available although £25-£30. Wiggle used to do them but you could try Sideways or Charliebikemonger.
Is your chainset Compact Drive, if so Middleburn do one, available at CRC;
http://www.chainreactioncycles.com/Models.aspx?ModelID=3323
The crankarms are shimano stx I think from an orange gringo, so not sure if compact, also how do I know what BCD this is...
measure it? http://www.sheldonbrown.com/gloss_bo-z.html
Centre to centre of adjacent arms/bolt holes times 1.7
I have measured the BCD and it's only 58, seems its a compact. The smallesy ring currently on it is a 32t, but its ramped, so I was looking for a SS specific one.
Just ordered a 32T 5-bolt, took me ages to find one with no ramps. Got a Surley new off Fleabay.
I carn't find anything this small, any suggestions... I might have to bite the bullet and get a cheap crankset.
What is the centre-centre measurement of two adjacent mounting holes?
About 55.3mm?
Surely 58mm BCD is for the granny ring? Should have an outer circle of 94mm which is called 5-bolt Compact Drive (CD). You can get Surly's rings for this down to 30T in 1T steps. They last for ages.
http://www.sidewayscycles.co.uk/products/index.php?id=466&clid=24
http://www.tritoncycles.co.uk/products.php?plid=m13b0s298p4320
My crank arms only allow for fitting a granny ring, the rest attach to that? Any ideas?
A photo would help.
IIRC stx had an arrangement whereby all rings clamped on to the granny sockets.
I suspect you may be ****ed.
cynic-al, thats the fella... and even harder to belive, I have 2 sets of these cranks... I could try it with the ramped 32 and see what happens.
I wouldn't be sruprised if Madison still had stock of the middle rings, worth a try.
