Singlespeed chain -...
[Closed] Singlespeed chain - bimbo needs advice please
[#1852143]
Evening. Was full of good intentions and decided to thoroughly degrease my singlespeed chain. Now I knew that it was different/stronger to my usual Sram but didn't realise it was Shimano. 😳
So, my question is, do Sram make an ss chain cos I like their power links?
Thank you so much. 🙂
Posted : 01/08/2010 8:19 pm
Yes, SRAM do make a singlespeed chain.
[/Thread]
Posted : 01/08/2010 8:22 pm
Yes they do but they all (AFAIK) have the same way of splitting/joining, called a split link IIRC.
Posted : 01/08/2010 8:23 pm
 Spud
PC1 IIRC. Less than a fiver in Decathlon.
Posted : 01/08/2010 8:28 pm
Sram 8 speed chain using normal power links (the silver ones)
Posted : 01/08/2010 8:29 pm
I'm confused! I can cope with using a power link as my other bikes all have Sram.
To make matters worse, my chain tool has broken. 🙁
Women's logic dictates that C_G's stable should all be Sram. 🙂
What's a girl to do?
can you not just fit a sram powerlink to a shimano chain.
Posted : 01/08/2010 8:32 pm
stop cleaning ?
stop cleaning ?
I think not! 😉
Posted : 01/08/2010 8:33 pm
Do shimano do them?
Posted : 01/08/2010 8:35 pm
Split links will fit any chain as long as it's the same width ie. SRAM 8 speed split link will fit Shimano, KMC etc. 8 speed chain.
Posted : 01/08/2010 8:40 pm
Guys, I only know how to clean chains and, even if I say so myself, I do a pretty good job. 8)
I thought Sram/Shimano weren't interchangeable?
C'mon, surely someone on here can answer this? 🙄
Posted : 01/08/2010 8:43 pm
sram links fit shimano chains
Why not just use the same chains as your other bikes?
Posted : 01/08/2010 8:50 pm
as TJ says, SRAM links work fine on Shimano chains
Posted : 01/08/2010 8:52 pm
OK, thanks for replies. Will check the Shimano chain against the Sram ones and have a wee experiment.
I thought the SS chain was more heavy duty/stronger?
Any recommendations for a chain tool? Disappointed that my Park Tool one that has seen little use decided to disintegrate. 🙁
Posted : 01/08/2010 8:53 pm
I doubt your chain cleaning prowess. I think this claim should be tested on my chain at the bbb. Have no idea about the other stuff tho.
Posted : 01/08/2010 9:00 pm
Thelinks only fit for the same size chain - so 9sp with 9 sp but not ss or 7sp with 9sp
Posted : 01/08/2010 9:05 pm
check out charlie the bike mongers web site or give him a call for advise on chains a really help full shop 🙂 specially with single speeds .
Posted : 01/08/2010 9:12 pm
CTBM is a top man - full of helpful advice.
You broke a Park Tool.... HOW?
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=10185 ]Cheap ones work just fine. CLICKY[/url]
Posted : 01/08/2010 9:18 pm
Rich - even my lbs were impressed with my cleaning! Was recommended some really good degreaser, I leave it overnight and then get scrubbing in the morning with a nail brush. But my bikes are [b]always[/b] cleaner than yours!!
OK, so I now haven't a clue whether the ss chain is for an 8/9 speed!
Good call for Charlie, he seemed a really nice guy and gave me a sticker at the Purbecks Forum Ride. 8)
Posted : 01/08/2010 9:20 pm
Woody - it was a folding one that is now discontinued, hmmm wonder why!! Thanks for that link. 🙂
Posted : 01/08/2010 9:22 pm
CG - SRAM chains are not all that - my son broke one in less than 1 day. KMC chains get good reviews from the touring crowd (ie. singlespeed, hub gears) and I splashed out on a KMC gold SL last year - shows no sign of wear when I would expect it to. Or you can go BMX chain which only works with thicker sprockets/chainrings but is strong although heavy.
Posted : 01/08/2010 10:37 pm
As per Rich 8 speed SRAM with the silver powerlink
Posted : 01/08/2010 10:46 pm
KMC Z610HX - good chains and only about a tenner.
They just join with a split link.
Posted : 01/08/2010 11:01 pm
