Single speed road c...
[Closed] Single speed road chain set options
[#7430655]
Possible stealth wanted ad alert.
I need a new chain set for my pompetamine.
It is currently running an FSA double chain set, running just one ring.
Any reason to change to a single chain set or should I stick with the double and 1 ring?
As a follow up has any one seen any good deals on suitable chain sets?
Thanks
Posted : 02/11/2015 11:20 pm
 JoB
all my singlespeed chainsets have been doubles with just a single ring on, never been a problem
Posted : 02/11/2015 11:24 pm
Thanks Jo. Any reason I can't use MTB crankarms assuming I can find a suitable chain ring??
Posted : 02/11/2015 11:35 pm
 JoB
there might be issues fitting an MTB chainset to a road bike, chainline, BB axle length, crank clearance, but there are many variables, it's been bodged before though
Posted : 02/11/2015 11:58 pm
it depends on the rear spacing of the frame and the wheel that goes into it to define the chainline - for a pompino the use of a double with a SS ring on it is the best solution so I'd stick with that.
Posted : 03/11/2015 12:12 am
Pompetamine is 135mm rear spacing innit, so you should be OK using just about any crank really, assuming the rear hub isn't too whacky...
Can you not just get a SS type ring and some shorter bolts, for the existing crank?
[url= http://www.velosolo.co.uk/shopcrank.html ]try here...[/url]
Otherwise If you have to get new cranks how's about a nice pair of stronglights and a square taper BB?
Posted : 03/11/2015 12:29 am
Thanks all. I don't NEED new cranks, but the BB on the current one needs replacing and I only just realised it's an Fsa with a 19mm axle so it seems like a good idea to swap it for something more standard
Posted : 03/11/2015 8:38 am
