hey quick question re: building up a voodoo wanga as a ss. Can i just use normal Hollowtech II cranks ie ones with mounts for 3 rings?
Will i be able to find a 32T ring which i can set in the middle ring position?
really appreciate the help!
Posted : 24/11/2009 1:51 pm
yes. but you need short bolts. try charlie the bike monger. 😀
Posted : 24/11/2009 1:52 pm
yes and yes
you may need to buy shorter chainring bolts depending on the thickness of the ring tabs.
Try Charlie the bike monger. I use a 36 tooth Salsa ring at the moment
thomthumb/paulosaxo- thank you. problem solved
Posted : 24/11/2009 1:54 pm
