Single-sided truing...
[Closed] Single-sided truing stand
[#9975232]
I'm thinking about buying the Feedback Sports wheel jig, but have realised that the more expensive stands have a lateral adjustment guide on each side of the rim.
However, other cheap stands only have a single guide, even if they're of a more standard double sided design (the Feedback Sports on is a simple single upright pole).
Does a jig with single guide make it much more difficult to true a wheel compared with a jig with two guides?
Presumably you can flip the wheel over if you need the guide on the other side of the rim, but perhaps a single guide makes things more awkward!
Posted : 07/05/2018 8:52 am
Both sides is easier. Flipping the wheel quickly gets annoying.
Posted : 07/05/2018 9:07 am
How often will you be doing this?  I've only ever had single sided and while double sided would be nice it's never caused any sort of problem
Posted : 07/05/2018 9:30 am
Double sided is only an advantage if set up perfectly for dish. As an occasional wheel builder I'd be happy with single sided and a dishing gauge. Most important to me would be the stand taking every hub size and rim size I needed, being easy to use and solidly constructed  so nothing wobbles
Posted : 07/05/2018 9:38 am
"Both sides is easier. Flipping the wheel quickly gets annoying."
why would you need to flip the wheel ?
I dont have one , i want one but i find it excruitiatingly expensive for what it is....
dont even have to remove tire for a quick true on a 29er or even a fatty - sold.
If building lots of wheels id prefer my old set up of calibrated ts1/ts2  mounted to a stool.
If building regular wheels you knew 100% that the dish was spot on if she was between the pointers - quick check with the VAR gauge at the end and life was good.
But then that set up was 3 x the cost of the feedback sports - and took up significantly more room.
Posted : 07/05/2018 12:30 pm
You can check dishing by flipping the wheel.
Posted : 07/05/2018 12:37 pm
"You can check dishing by flipping the wheel."
while you can i always found it easier and quicker to use the gauge - especially if building offset wheels as you can set the gauge up to your offset and build to that .
with the caveat that  if you have done your spoke calcs for the right offset then the amount of dish your sticking into a wheel should be minimal.
Posted : 07/05/2018 12:44 pm
Oh for sure. Not suggesting its the best way but it works and is easier than checking it with a tool you dont have.
And building a wheel on the coffee table whilst sitting indoors beats crouching over an upside down bike frame.
Its just  nicer not necessarily better to have a stand.
Posted : 07/05/2018 12:51 pm
Thanks very much.  I'm slightly more undecided now, though!  I'm not sure if the Feedback Sports stand is a wise buy, or if there's a better stand for similar money.  I've not built a wheel before, and I'm not sure how much use it will get.  I thought it would be wise to get the basics down before looking at a P&K Lie stand!  I've read some reviews on other budget stands, and some of them are reported to be relatively flimsy, or be just "okay for the odd truing job".
Posted : 08/05/2018 3:37 pm
Whats about a X tools Pro truing stand? Its similar money. (never used one but looks more like a normal truing stand)
http://www.hotlines-uk.com/x-tools-pro-mechanic-wheel-truing-stand
Posted : 08/05/2018 6:02 pm
that Xtools one looks very nice for the money but the real question is how rigid it is.  The other Xtools stuff I've seen has been quite nice though so I would be very hopefull
Posted : 08/05/2018 6:36 pm
