Single Ring?
[Closed] Single Ring?
[#2876504]
For my next bike I thought I might for go to a single ring on the front, not quite ready for SS yet!
What would be the best front rear combo for a 120mm travel hardtail, used primarily over Kinver/Clent/Wyre/Peaks, you know, general pootling.
8,9 or 10 speed rear?
Posted : 22/06/2011 1:01 pm
If you're starting afresh, may as well go 10spd with as wide a range cassette as possible. I run a 12-36 cassette and 32t ring on both my bikes and thats spot on for Calderdale where I live plus its coped ok in the Lakes, Peaks, trail centres etc.
Posted : 22/06/2011 1:12 pm
Cheers matey . .
What's the secret to running the chain most efficiently?
Posted : 22/06/2011 1:38 pm
Are the extremes of the cassette really usable, and what front ring do you use?
Posted : 22/06/2011 1:39 pm
Yes they are fully usable. Definitely agree that if you're starting afresh you should go 10 speed.
I use a 10 speed 11-36 with a 36t ring (personally a custom made ti one from Matias Helore), I'd personally find a 32-12 top gear undergeared, but it'll depend on you.
Posted : 22/06/2011 1:41 pm
The extremes are very usable. I was a doubter before this but built up a 456 Summer Season on the cheap and ended up trying out 1x9 on that. Had me hooked so rebuilt the Blur 4X with a similar setup.
Use an MRP ring on the Blur and an On-One stainless SS ring on the hardtail. Big diffence in weight between the two but suspect the On-One ring will outlive me!
Posted : 22/06/2011 1:43 pm
