Simply question ref...
[Closed] Simply question ref: XTR gear cables
[#1795983]
Hi peeps,
Simple question for the seasoned builders out there but new one for me so please bear that in mind 😛
My XTR shifters came with the outers, which is fine, and as I am running an open system I have all the outers I need, but.... the pack came with what Shimano call 'rubber shields' and I'm not 100% on where exactly to use them.
Now I'm guessing that once the outer goes through a frame stop and the little plastic thing is sticking through the other side of the stop that the large end of the rubber shield just slips upto it and provides a bit more cover, not alot but some I guess?
Its too big to fit into the frame stop and with the cable outer and also there is still a gap between the cable outer and the rubber shield? I don't recall seeing them on peoples frames when they show their pics? So do peeps just not use them at all, as I can't really see a point in them?
Have I missed the point or where to place them?
Cheers all 😀
Posted : 13/07/2010 6:08 pm
Use them on my road bike, great stuff but I bought a few when cheap.
Now I see it as a rip off personally.
Posted : 13/07/2010 6:13 pm
sorry Frankenstein, after typing the first line I accidentally hit the send post button when I needed to type the question in full, doh! 😯
Posted : 13/07/2010 6:15 pm
correct
cable end stop once side the frame stop and rubber boot on the other
like:
- i use them, though the price of the cables has rocketed nearly twice the cost they used to be - seem to work well though
Posted : 13/07/2010 6:21 pm
Ah thankyou rootes1, just the info I needed 😀
Do they just stay put or do they seem to float about etc? As they aren't inside the frame stop, or have you managed to squash yours in?
Thanks again.
Posted : 13/07/2010 6:25 pm
Does anyone know how to stop them moving off?
Posted : 13/07/2010 6:49 pm
Tiny dot of superglue works for me.
Danger Mouse - I'm fairly certain the instructions show the rubber boots are meant to be fitted.
Posted : 13/07/2010 7:20 pm
They shouldn't move as there is a small projecting lug on the end of the plastic ferrule which grips the rubber sleeve.
Posted : 13/07/2010 7:26 pm
They keep water in nicely!
Posted : 13/07/2010 8:16 pm
[i]They keep water in nicely! [/i]
Yeah, they must hold, what? Microns of water in there... 🙄
Oh, the horror! will someone think..etc etc
Posted : 13/07/2010 8:28 pm
Takes little to rust my good friend nickc.
Posted : 13/07/2010 8:33 pm
They stay put without any glue etc on my bike, seem to keep the water out.
Posted : 13/07/2010 10:12 pm
