Have juicy caliper on fox IS fork running 160mm disc. Want to mount on post mount fok with same disc. Looks like it will just go on a post mount. (dont say try it as dont have forks until next week....wondering whether i need any adaptor before forks turn up).
I assuming it will just fit
cheers
You will need an adapter to go for post to I.S. only problem is you will need a 180mm rotor as well, i don't think anyone makes an adapter that allows you to run the same size rotor (but could be wrong)
cheers......going the other way - its IS now and needs to go to post.
A post mount caliper just bolts straight on to a post mount fork with no adaptor for a 160 disc
I have done this in the past and yes, if you are using a 160mm rotor you just leave off the adapter and mount the caliper and conical washers straight onto the fork.
Cheers for that.
