Silly Gear Ratio Qu...
[Closed] Silly Gear Ratio Question
[#2716160]
Is a 2:1 ratio ever going to change the efficiency of pedaling?
E.g.
Will a 32:16 pedal the same as a 24:12 or a 40:20?
I expect the answer to be no but I cannot get my mind in gear this morning and decide for myself!
Posted : 04/05/2011 11:58 am
you may get marginally more friction with a 40:20 and less chain security with a 24:12 but they'll pretty much pedal the same on the same size wheel.
Posted : 04/05/2011 12:00 pm
wwaswas - Member
That what I though - well I think I did! 😆
Thank you 8)
Posted : 04/05/2011 12:01 pm
With larger chainrings and sprockets there is less friction in the chain due to the smaller angle through which each chain link has to turn as it conforms to the sprocket. This makes using larger sprockets more efficient. I’ve no idea how much more efficient though, I’d bet you’d not be able to notice. Larger sprockets will last longer though, so that’s a good enough reason to use them.
Posted : 04/05/2011 12:09 pm
crogthomas - Member
Why is that?
Posted : 04/05/2011 12:12 pm
Load and therefore wear is spread over a greater number of teeth. Ever noticed that it is the smaller sprockets on a cassette that seem to wear out first?
Posted : 04/05/2011 12:16 pm
crogthomas - Member
Thought this was solely down to usage 😳
Posted : 04/05/2011 12:24 pm
Smaller sprockets are definitely not as good.
I used a 22t chainring for Iditarod in 2009 and wore it out in 350 miles. I used a 28t front and a bigger rear this time and it was still in decent shape after 100 miles.
Posted : 04/05/2011 12:49 pm
my lbs was on about top dead centre the other day, not the faintest idea what that is but bigger is better according to him.
Posted : 04/05/2011 12:54 pm
Bigger cogs need a longer chain (assuming singlespeed), making more weight, making it tougher when climbing.
Otherwise I'd say it's down to wear (more on smaller cogs).
Oh, the other point is that if it's on a bike with suspension, the cog size will change the chainline and potentially affect the linkage, giving a reduction in efficiency.
Posted : 04/05/2011 12:55 pm
