Side entry bottle c...
[Closed] Side entry bottle cages?
 ben
[#10864958]
What's the best out there? Preferably available right/left handed so I can have same side access on down and top tube?
Posted : 15/10/2019 1:10 pm
Check out Fidlock bottle/Cage, its a twist to remove design, the bottle is held on by magnets and clamping.
Posted : 15/10/2019 1:15 pm
Spesh Zee.
Top notch kit.
Posted : 15/10/2019 1:18 pm
Zee cages. I have 4 on two bikes. Team them up with Specialized bottles too for a perfect fit.
Posted : 15/10/2019 1:23 pm
Zee.
Posted : 15/10/2019 1:24 pm
I use Zeefal Wiiz cages, they can be adjusted to be open on L or R side
Posted : 15/10/2019 1:25 pm
Zee here too - though they seem hard to find in black at the moment.
I have one on my Hightower. Slightly better value that the new Santa Cruz side-entry job!;
https://www.jungleproducts.co.uk/shop/product/santa-cruz-carbon-bottle-cage-right-hand/2529/
Posted : 15/10/2019 1:29 pm
Zee. I think they have superseded it with a new model which is why it’s hard to find them...
Posted : 15/10/2019 1:30 pm
I ended up getting a Zefal 'Wiiz' as it was cheap (~£4), has longer slots to allow me to shuffle it as far down as the frame will accommodate, and re-configurable for LH/RH, Down/Seat tube positioning.
No bottle ejections yet and I can just about squeeze a 750ml bottle in.
For the money I'm pleased with it for now...
Posted : 15/10/2019 1:40 pm
 ben
Cheers all, will have a gander.
Posted : 15/10/2019 1:49 pm
Zee, so I run a Lezyne one that isn't as good of course (needs a certain shape of bottle to fit in properly, and Lezyne only make them in one size)
Posted : 15/10/2019 1:52 pm
Lezyne side load on my Hightower. Never had a problem with it
Looks like Zees are back in stock on the Specialized site now, I guess that means dealers will be able to order them in too? https://www.specialized.com/gb/en/zee-cage-ii--right/p/172378?color=274170-172378
Posted : 15/10/2019 5:04 pm
The Lezeyne one I used dropped a bottle just going down the garden path. I would avoid at all costs.
Posted : 15/10/2019 5:13 pm
Zee, no question. Got them on both our FS with Spesh bottles for added compatibility. Never dropped a bottle, even when the bike went cartwheeling down the trail at BPW.
Posted : 15/10/2019 6:37 pm
Syncros tailor left/right worth a look. Colour options too if you're looking to coordinate.
Used them since they were launched and their retention is solid with any of the bottles I've used.
Posted : 15/10/2019 7:02 pm
Fidlock has been the best I’ve used. Been running one on my rocket for the best part of a year and never lost a bottle or had any issues.
Posted : 15/10/2019 7:34 pm
i love my fidlock set up too but the bottle doesn't squish like an ordinary one so you can't squirt it into your mouth, wasn't aware i did this so much until i couldn't.
Posted : 15/10/2019 9:33 pm
 ben
Cheers, I do like the look of the Syncros. Will try and find both to have a play with in real life.
Posted : 16/10/2019 12:18 pm
I've got a Specialized one and also a cheapo one from Decathlon which can be mounted either way round. Had plenty of use on long tours/rides with luggage and performed just fine.
Posted : 16/10/2019 5:37 pm
Zee, Zee and again - Zee
Posted : 16/10/2019 6:42 pm
I use a cannondale GT-40 side entry. light and hold the bottle well
Posted : 17/10/2019 1:02 pm
