Show me your Rocky ...
[Closed] Show me your Rocky Ridges
[#1071144]
Just about to rebuild my 06 RR into its third reincarnation - let's see your modified RRs for inspiration...
Posted : 24/11/2009 8:43 pm
Go on then:
Surprisingly, spec still current. Go on, as a fellow owner of an 06 try a little spot the difference.
Posted : 24/11/2009 9:57 pm
Everything except frame and saddle...?
Posted : 24/11/2009 11:27 pm
Here's my '05 Rocky Ridge, no longer with me.
Posted : 24/11/2009 11:47 pm
Not very close up. Mostly stock except a 2.4" ADvantage on front and a 2.2" UST Rubber Queen on the back, both ghetto tubeless.
New Thomson stem and seatpost, and flat Salsa bars (680mm wide though!).
Shortly going to be replacing either the BB or the BB and cranks, depending if i can source some old school octalink cranks for it.
Posted : 25/11/2009 12:12 am
Not a bad guess! Saddle isn't original, it met its maker after trying to learn how to jump! The original shifters and front mech are still alive and well, but not fitted (I went thru a multi-bike phase). The one you missed is the stem, its original, though it does creak.....
Best bike I've had but I guess in a Trigger stylee, its had 5 new shanks and 3 new heads!
Posted : 25/11/2009 9:29 am
