I need some bling! Can you include method and time taken, cheers 😀
Wow! What cranks are they?
looke like XT to me................... is there a prize 🙂
Deore with holes drilled through to look like XTR (ish), nice anyway and the exact cranks I have on my SS, hmmmmm I know a powdercoater as well
Just what i need on my Ti 'cross project.
Looks nice, I better took some do'ing 😥
Get your googling going for local metal finishers, a chroming place, powder coaters, they will all do ally polishing, or at least point you to somone local who will..
I did these old Saint cranks in a fit of boredom, haven't got quite the good finish like on the ones above but these are only hand polished, if I bought a buffer I am sure I could get them a lot better.
I did it with Kleen-off oven cleaner, you are looking for it to contain Sodium Hydroxide.
Basically took a little while, stuck cranks in bucket, sprayed with oven cleaner and left for 15-20 mins and then scrubbed the loose anodising off with a green pan scrubber and repeated about 6-8 times until all the anodising was removed. Gave it a quick buff with Brasso. I think if you use Autosol and a buffer you could get it to a better finish. I did try it with fine wet and dry but found it too much like hard work and the oven cleaner worked better without scratching.
[url= http://farm3.static.flickr.com/2672/3983417080_bcbffc4c11.jp g" target="_blank">http://farm3.static.flickr.com/2672/3983417080_bcbffc4c11.jp g"/> [/img][/url]
Oh polished! I thought you meant scuffed ;0)
OxymOrOn are they RF evolve? Maybe I should do mine instead of forking out for some eno cranks? What method did you use?
[url= http://www.finishing.com/217/46.shtml ]shiny metal process[/url]
this linky explains it all (sort of). They are chatting about Motorcycle frames, but metal is metal.
No, old RF Turbines I bought off here.
I got a pack of different grades of wet and dry that I worked my way through, then used a metal polish from Halfrauds at the end
Keep 'em coming
