Show Me Your...Bird...
[Closed] Show Me Your...Birds
I started at 350, but it was a bit firm and I and I didn't need to dial in any LSC so I swapped for a 325.
How do you find the 400 spring?
Posted : 16/05/2020 1:28 pm
null
Looking for one of the Bomber coil shocks but I can't find one in stock at 230x65.
Posted : 16/05/2020 4:17 pm
What fork travel are you guys using in your AM9s?
Posted : 16/05/2020 8:02 pm
null
After my 203 f/r upgrade today.
Posted : 16/05/2020 10:06 pm
Bluebell Bird
Ah ha. There is no image command on my iPad. I Was trying to use the IMG command. I didn’t realise that isn’t necessary on iPad. Not sure that’s totally intuitive (not to use the IMG command). But now I know. Thanks.
https://imgur.com/gallery/sja7Aqq
Posted : 17/05/2020 12:03 am
 tdog
Blimey! Who knew posting up pics of birds was so complex
Posted : 17/05/2020 12:27 am
Aeris coil owners..... Did you find that you had to size up or down on the spring calculator when choosing the right weight springs..... I just about to hit buy and can't decide coil or air.
Posted : 17/05/2020 8:36 am
160. I know it’s only warranties to 150.
Posted : 17/05/2020 10:25 am
I have a 160mm Lyrik on mine and three other AM9 owners I know are running 160mm forks too.
@hamishthecat - I can't recall where I read it (Ben Pinnick on here maybe) but I thought the latest version of the frame had met the testing criteria for 160mm forks, so I would have hoped the warranty would be changed to reflect this. There's no mention of 160mm on the website though, and all of the fork options are still 150mm, so I'm guessing the warranty is still officially 150mm.
@ifindoubtflatout - I opted for a lighter spring. A couple of spring calculators had me around 350lbs but I already knew that I needed to run more sag to get the best out of the air shocks I tried (RS Super Deluxe & CCDB Air), so I also bought a 325 spring and that's the one that worked best. The 350 was just too firm in the second half of the stroke, and even with the lighter spring fitted I still didn't need to add much LSC.
Posted : 17/05/2020 11:04 am
Aeris coil owners….. Did you find that you had to size up or down on the spring calculator when choosing the right weight springs….. I just about to hit buy and can’t decide coil or air.
If you buy a coil mail us your weight and desired sag and we'll get the right coil for you.
The V3 frame is rated to 160mm. That launches 'officially' (we've shipped a few already) in the very near future.
Posted : 17/05/2020 11:32 am
@Yetiman. I'm in between weights as well so I was thinking of going down a size, cheers for that.
@benpinnick. I was going to give you a call in the morning regarding the order if your about.
Posted : 17/05/2020 11:51 am
I’ve got a lovely Zero TR, unfortunately not been ridden in nearly a year due injury, must get round to selling it..
[url= https://i.postimg.cc/wBpQw5dH/A1263870-E93-E-4-E4-F-9-CC6-12-ADF5-D92-BE4.jp g" target="_blank">https://i.postimg.cc/wBpQw5dH/A1263870-E93-E-4-E4-F-9-CC6-12-ADF5-D92-BE4.jp g"/> [/img][/url]
Posted : 17/05/2020 12:01 pm
I'm on a 375, no LSC. Are you meant to need LSC?
I have a 350 which I meant to pickup today but forgot, will be another few weeks before I manage.
I did grab my Megneg Deluxe as I might try the new linkage and it's meant to be good with that. So far, coil has been good but not tested on much big this year.
Posted : 17/05/2020 2:08 pm
My Bird Zero Mk1.
I bought the frame second hand about 3 years ago and built it up from a mixture of parts from my spares stash and bargain buys.
The guys at Bird are great and I had some valuable advice from them when I was building the bike.
It's a brilliant bike and I am currently saving up to buy a Zero 29. I just wish Bird would do the 29 frame in some better colours.
Posted : 17/05/2020 3:02 pm
@benpinnick
Thanks for the updates.
Was the spec of the V3 changed to allow for 160mm forks or was simply a matter of validation re-runs?
Posted : 17/05/2020 8:04 pm
So, i finally got to ride my Aeris today at QECP, it's my regular for the past 12 months ive been riding, also the first dry day this year ive been.. dusty.. and this thing smashed my PBS across the board..and wasn't too shabby on the climbs either
my first full squish, and it's a big bike, ran wide a few times.. but what a beautifully controlled machine.
gave myself a squeeky bum on the little tabletops when i realised the back end on full sus bikes really like to help out... i put on a click of LSC to see how that worked out, i figured more rebound would do it, but... it felt right... and if i put LSC on more of my pump would go into the front.. that was my logic anyway..
still used all but a few mm of travel on the back though...., not that i could notice...
Posted : 17/05/2020 10:53 pm
https://flic.kr/p/2he7qL N" alt="My AM9 " />
Posted : 19/05/2020 12:29 am
That looks cool Clarky. Your IMG tags are broken though. Allow me:
Posted : 19/05/2020 12:32 am
Thanks!
Posted : 21/05/2020 12:31 am
We increased the thickness of the DT and Seat tube. Our testing (which is considerably more robust than ISO) was too close a call for us to warrant the previous version to 160mm.
Posted : 21/05/2020 6:15 am
https://drive.google.com/file/d/16GQ-IXfPKJOzds04LnLzznXEJqbRKlUf/view?usp=drivesd k" alt="null" />
Posted : 25/05/2020 10:33 pm
https://photos.app.goo.gl/C4aDmJGwh48AWZ71 8" alt="null" />
Posted : 25/05/2020 10:44 pm
https://photos.app.goo.gl/qG9jV8vfw6VBFALV6
Posted : 25/05/2020 10:55 pm
Rekindled my love of my Zero TR today! A couple of days ago I removed both mudguards (RRP + MH), replaced failing dropper with regular seatpost, tightened rear hub so that freewheel doesn't fall off (and discovered the gears didn't need fettling after all), and cleaned drivetrain and putolined chain. Was running great today, really enjoyable ride which most people would say was more gravel orientated, but it's nice to play around on the TR.
Posted : 25/05/2020 11:15 pm
https://imgur.com/a/QUCNb8b
Posted : 25/05/2020 11:36 pm
My 145LT
Posted : 26/05/2020 10:49 am
The new V3 AM9 is now on the Bird website. There's two new colours to go with the raw and 170mm forks confirmed. Shorter seat tubes as well.
Bird AM9 V3
Posted : 10/06/2020 4:04 pm
Show me some AM9s so I can convince myself they are pretty and I want one!
Posted : 10/06/2020 8:46 pm
Mine from a few posts up is in the classifieds now at £1400 ono, local collection or delivery central Scotland...
Posted : 10/06/2020 8:56 pm
Mine from a few posts up is in the classifieds now at £1400 ono, local collection or delivery central Scotland…
I'm after an AM9
Posted : 10/06/2020 9:14 pm
Iainc has a Zero. Join the Bird owners FB page ogden, loads of owners there
Posted : 10/06/2020 9:31 pm
Sorry, yes, it’s a Zero TR that I’m selling.
Posted : 11/06/2020 9:02 am
Any AM9 users around here weighting between 88-90kg geared up with a coil shock? If so, what spring rates are you using? Also, please specify which link that's with
Posted : 16/06/2020 6:51 pm
Anyone?
Posted : 17/06/2020 7:25 am
Any AM9 users around here weighting between 88-90kg geared up with a coil shock? If so, what spring rates are you using? Also, please specify which link that’s with
It differs to the online calculators, the tf tuned calculator suggested a 400 but I emailed Bird with all my details and they said I needed a 450 at 85ish with my gear on. Drop Dan an email at Bird and he’ll sort you out.
Posted : 17/06/2020 8:47 am
 d00m
My Bird Zero TR
My Zero Tr with the newly added Pikes and 11 speed groupset.
Posted : 17/06/2020 1:05 pm
Page 2 / 2
