Just fitted my Alfine 8 speed hub and need some ideas on setting up the shifters.....
Thanks
er... mine is clamped to the bar the only way it can
Trying to get a comfortable angle for it and position relative to the brake lever. Just doesn't feel right at the moment.
mines on mary bars - rotated so far round the bar ( window away) that I can hardly see the window
I found the paddles being the 'wrong' way round a bigger issue than positioning the shifter on the bars, but will try to remember to take a photo of mine on the way to work tomorrow morning and post it up.
I wonder. Are the Alfine hubs compatible with Shimano's DCLs ?.
Or is my thinking too "joined up" for a company such as Shimano ?.
not compatible. they only work with Alfine trigger shifter, nexus twist shift and the jtek bar end shifter
..... and versa drop bar shifters.
geoffj just beat me to it. Versa 8sp levers [url= http://www.on-one.co.uk/i/q/BLVEVRS8/versa-vrs-8-brake-levers-pair-for-alfine-8sp ]reduced[/url] at On One.
ah, I didn't know about them. I also know a guy running one on a thumb shifter with a travel converter
i have removed the window to get the shifter in the correct position for my tiny hands.
@ChunkyMTB Thanks! Hadn't thought of mounting it like that!
@bobbyspangles How hard is it to remove the window?
I have big hands so the setup works for me.
Fits quite neatly with deore levers, although I probably would have preferred to have the brake lever inboard of the shifter. Didn't fancy taking a hacksaw to a new bit of kit though. However, I did do that with an old deore derailleur shifter and it was fine.
Also had my first alfine puncture this morning and I'm pleased to report it wasn't too much faff at all. Having said that I was running a mechtug arrangement before the hub gear and that was a total nightmare to sort out flats.
quick bump for the bobbyspangels question as I also fancy removing mine.
You just unscrew it on the one I've got.
I did wonder but I once did that on another shifter and the whole thing fell apart. wasn't too keen to try it again
Wanted the brake lever further inboard of the shifter, so I took a hacksaw to mine...
[url= http://farm5.static.flickr.com/4034/4655329217_522d754b1b_z.jp g" target="_blank">http://farm5.static.flickr.com/4034/4655329217_522d754b1b_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/32746168@N08/4655329217/ ]IMG_9201[/url] by [url= http://www.flickr.com/people/32746168@N08/ ]ten_sim[/url], on Flickr
just unscrew it
mine looks like its all one part, window and shifter body.
