Thinking of fitting a 29+ on the front of my ss el Mariachi - please show me your set-ups, especially if you have cro-moto forks
Thanks
Sorry it's not a very good picture.
Almost as smooth as when it's got a fatfront on but quite a bit quicker on the climbs.
[url= http://farm8.staticflickr.com/7369/8729462712_c529975f8a_z.jp g" target="_blank">http://farm8.staticflickr.com/7369/8729462712_c529975f8a_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/stu-b/8729462712/ ]20130511_104256[/url] by [url= http://www.flickr.com/people/stu-b/ ]multispeedstu[/url], on Flickr
[url= http://farm8.staticflickr.com/7323/8726937666_07bdefbe9e_z.jp g" target="_blank">http://farm8.staticflickr.com/7323/8726937666_07bdefbe9e_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/stu-b/8726937666/ ]Rabbit Hole rim and Knard tubeless for the Jones.[/url] by [url= http://www.flickr.com/people/stu-b/ ]multispeedstu[/url], on Flickr
Thanks stu - did you get a complete wheel with surly hub? Thinking about pro2 evo for flexibility...
Did you do anything special to set it up tubeless?
Surly hub? 😯
No mate it's a Whub. 🙂
Gorilla tape and a bolt in vale for tooblessing.
All the Surly rims work dead easy like that.
Tazzy, is that a Black Sheep?
Bloomin lovely whatever it is 🙂
yep a sheep, with a torus/burls Ti fork, 29 x 3 fits lovely with plenty of space.
Sorry no photo but would be worthwhile checking the fork width. I've got one in my swift fork mounted on a P35 rim and there is only a couple of mm clearance on each side of the tyre. It's fine for my testing purposes as a stepping stone to fat front but i'm not sure it would be much use in the winter with whatever 29+ nate equiv surly release.
OK so what is 29+
OK so what is 29+
50mm rim and 29x3" tyre.
OK so what is 29+
At the moment, as far as i'm aware, it's Surly's Knard tyre and nowt else. Fits on a 29er rim but is about 3" wide and as a result is relatively high volume. Knard at low pressure works nicely on rigid fronts to provide a bit more cushion.
Ron Jeremy - that looks like standard 29 in a 26 cro-moto?
Taz - what is the width between the blades on your forks please?
Thanks all
Gota.
They might fit on a standard 29er rim but that's kind of missing the point of a 3" tyre. 😉
Oxy,
Yep had a 29 wheel and a 26 fork, so just thought I'd see if it works and it does and rather well too
Stu - fair point and worth clarifying; building a wheel up from scratch a rabbit hole would definitely be the way to go. In my case it was just a test since i had the p35 built up and i'm patiently waiting for a jones test ride.
I've been considering 29+ in my DT Swiss rigid fork (which has dimension similar to Tazzy's Ti fork by the looks of it; plenty of room).
If anyone is upgrading to a Rabbithole wheel and wants to sell their P35 rim or complete wheel (on a 100mm hub, no Jones hubs please!), drop me a msg.
Giant XTC Composite and Pace 445mm forks.
[URL= http://i1117.photobucket.com/albums/k581/willberesford/101.jp g" target="_blank">
http://i1117.photobucket.com/albums/k581/willberesford/101.jp g"/> [/IMG][/URL]
Anyone know if 29+ is feasible with an On-One Carbon fork?
