Should I swap my E1...
[Closed] Should I swap my E150 fork(s) for a 2010 Talas RC2?
[#1365044]
Right, looks like I'm going to stick with the Enduro SL for a while (no bad thing!), so since I'm not spunking out on a new frame, I thought I might get a new fork instead 😆
Currently running two bikes with Specialized E150 forks, the Enduro (came with the bike) and an Orange Sub Zero (picked up a spare E150 a while ago just in case the first played up, never has though 🙂 )
I'm tempted to sell both forks and pick up a 2010 Talas RC2 from Si @ Progressive bikes, with the view to swapping it between frames as and when I feel like it, sound like a plan?
What have been folks experiences with the new 2010 Talas RC2? Will it be a noticeable difference to the E150 do you think? They're 160mm-130mm-110mm adjustable right? Do they run OK set at 130mm permanently (as they'll be for the Sub Zero)?
cheers STW 🙂
Posted : 26/02/2010 8:34 pm
 br
Fox 36's are a fair bit heavier than the E150's, and would probably spoil both bikes...
I'd spend the wedge on something bling.
Posted : 26/02/2010 8:46 pm
2.6kg for the E150 (inc stem and axle) and 2.26kg for the Fox? Liking the look of the Point One Split Second 70mm stem (139gm), so Talas + Stem = ~2.4kg, or am I missing something from my equation?
Posted : 26/02/2010 8:57 pm
I got some 2010 36 Talas RC2's from Si in the new year, they are running great. They are 160-130-100. I run them in 130 quite a lot, just extend them at the end of the ride..........doubt I really need to-I'm just like that!!
Posted : 26/02/2010 9:12 pm
Swap, (but, if you can, go lyriks :wink:)
Posted : 26/02/2010 9:15 pm
Funny you say that, been sorely tempted by a set of Industry Nine Enduro wheels in red & white 😆
Lyrics are heavier again? Any reason you'd suggest them over the Fox?
Posted : 26/02/2010 9:19 pm
 LoCo
The 2010 Talas is a superior fork in terms on damping and travel adjust system, I believe (don't quote me on this though) that the travel adjust in the E150 is maybe a copy of the Talas 1 system due to the patent lapsing after Talas 2 was introduced (we're on Talas 3 now).
Posted : 26/02/2010 9:20 pm
Most seem to be raving about the FIT damping, tempted to give it a go, the extra 10mm travel up front shouldn't hurt things too much?
Posted : 26/02/2010 9:22 pm
I've always had issues with fox forks and reliabilty, cracked lowers and worn stantion. I've found that rockshox's better in the uk conditons and really easy to give a strip down and service on your own (sram even have videos on youtube showing you what to do). Personnelly I find the odd gram here and there makes no difference, but quality/reliable forks do. Just my opinion mind.
Posted : 26/02/2010 9:29 pm
 LoCo
wouldn't think so, you'll probably want to upgrade the rear shock after riding with the fox's though 😮
Posted : 26/02/2010 9:30 pm
if you're the kind of person who keeps stuff clean and serviced then get the Fox's, they're lovely when they work
otherwise don't bother, I don't know whether the 2010s are any different but the service intervals on Fox are daft and they will end up pissing oil at some point and ruining your day
Posted : 26/02/2010 9:33 pm
Don't know if this is genuinely the case... I refer you to [url= http://www.singletrackworld.com/forum/topic/fox-fork-failures-survey ]this thread[/url] perhaps?
Posted : 26/02/2010 10:02 pm
psychle - Member
also got an SL here and the i9 wheels would be where my money would go. Don't be a sheep, stay with the E150!! 8)
Posted : 26/02/2010 10:07 pm
It is the right fork for the bike, 'tis true... mmmmm, I9 wheels, so very blingy 😆 8)
Posted : 26/02/2010 10:08 pm
especially if you're still running the godawful DT Swiss rims that mine came with. I went with some sturdy Sun MTX rims cos I haven't got the dough but I'd love the 25mm bolt through wheel set from i9
Posted : 26/02/2010 10:11 pm
I have a set of Traversees on there now, not particularily blingy, but nice wheels 🙂
Posted : 26/02/2010 10:13 pm
just seen your ad! looks like you're still not convinced?
Posted : 26/02/2010 10:17 pm
testing the waters...
Posted : 26/02/2010 10:18 pm
I only know from friends' experiences with Fox forks how frustrating they can be, particularly those forks that are worked hard
Posted : 26/02/2010 10:39 pm
get the i9's (how much for the traversees?) 😉
Posted : 26/02/2010 11:08 pm
