Should I buy used P...
[Closed] Should I buy used Pikes or new Yaris
[#7674644]
Trying to keep my mind off things by keeping busy building the bike.
I'm after some 150mm forks for the Orange 5 and don't know if I should go for s set of used RCT3 Pikes (around £350) or do I go for a brand new set of Yari (£408).
I know the Yari doesn't have the Charger damper and I've had Pikes before and loved them but the Yari's seem such good value and they'd be brand new.
Not sure what's best here.
Posted : 27/02/2016 2:18 am
Personally I'd go for the latter, seem to get good reviews and the warranty would give me peace of mind. Always difficult to check the life forks have had which would concern me more for a set like pikes which are likely to have had some harder use given the travel and type of bike they're typically fitted to.
Posted : 27/02/2016 8:17 am
I thought I remembered seeing a Pike on your 5 build?
I haven't used the Yari myself, but I'd be wary of a damper downgrade from the Pike - especially knowing that your riding will be rocky.
Posted : 27/02/2016 9:06 am
Where did you see Yari for £408? Cheapest I've seen is £415. Not much difference but pricing up a build on a tight budget.
Posted : 27/02/2016 9:13 am
What model are you after Akira?
Posted : 27/02/2016 9:41 am
Ideally 150mm boost in either 27.5+ or 27.5/29+.
Posted : 27/02/2016 9:55 am
Thats tough at the moment - can do you either 140 or 160 boost 27.5 but nothing else in a 110 axle right now (@408)
Posted : 27/02/2016 10:33 am
I'd go for the Yaris. Great around town and real easy to park.
Posted : 27/02/2016 10:37 am
Ah don't suppose you know the axle to crown on the 160s. I'm guessing the 29+ are just longer than the 27.5+, sram website not that useful on details.
Posted : 27/02/2016 10:42 am
I've had a go at a 160mm Pike and currently own a 150mm Yari.
Not a lot of difference in 90% of riding. The newer Motion Control damper is quite good. Plus, you could always upgrade to the Charger damper in the future.
Love my Yari so far.
Posted : 27/02/2016 10:45 am
So am I right in thinking the Yari is boost specific and there will be a gap on my standard 15mm hub?
I'm thinking new Yari at the minute. I'd need a 150mm standard 15mm drop out.
All the Pikes I can find are 2014 as well which I believe lack the later upgrades.
Posted : 27/02/2016 11:34 am
You can get them in Boost and standard. Mine isn't a Boost, 15mm thru and 150mm Travel.
[URL= http://i442.photobucket.com/albums/qq141/john190784/Mobile%20Uploads/DSC_0286.jp g" target="_blank">http://i442.photobucket.com/albums/qq141/john190784/Mobile%20Uploads/DSC_0286.jp g"/> [/IMG][/URL]
[URL= http://i442.photobucket.com/albums/qq141/john190784/Mobile%20Uploads/DSC_0285.jp g" target="_blank">http://i442.photobucket.com/albums/qq141/john190784/Mobile%20Uploads/DSC_0285.jp g"/> [/IMG][/URL]
Posted : 27/02/2016 11:43 am
New Pike for £480?
Posted : 27/02/2016 11:50 am
Jake where is that?
Posted : 27/02/2016 11:55 am
Pike and new seals / oil is roughly the same price
Easy choice for me
Posted : 27/02/2016 11:56 am
I've had a set of pikes before but never game them enough time to really understand the benefit.
£480 new is only £40/60 more than Yari which seems a no brainier.
Posted : 27/02/2016 12:01 pm
27 - 552 @ 160
29/27.5+ 571 @ 160
Posted : 27/02/2016 12:08 pm
Ben, can you get a standard 150mm Yari? Any better price than I've found so far (above).
Posted : 27/02/2016 12:17 pm
Cheers Ben, although everytime I see you post I end up on the Bird website so not a good thing....
Posted : 27/02/2016 12:20 pm
Yep £408 delivered not a problem on those.
Posted : 27/02/2016 12:30 pm
And do you have a price on a 2016 Pike? Same spec (150mm etc)
Hate to ask in here Ben, apologies. I can't find an email to get you on.
Posted : 27/02/2016 12:31 pm
Also interested in Pikes here...
Posted : 27/02/2016 12:51 pm
 poah
save and buy a new pike
Posted : 27/02/2016 1:00 pm
New pike I reckon
Posted : 27/02/2016 1:11 pm
Id buy Pikes today if Jake tells me where they are £480 🙂
Posted : 27/02/2016 1:19 pm
Sorry no stock in the 150s right now, and nothing at the depot either. Probably couldnt hit £480 either way to be honest!
Posted : 27/02/2016 2:01 pm
Ben, how do I contact you about the £408 150mm Yari's?
Thanks
Ian
Posted : 27/02/2016 2:15 pm
Give me a call on 0118 9960382. Will be here for around another hour.
Posted : 27/02/2016 2:23 pm
Ben, need to sort out rest of the build before getting forks but I'll give you a shout when I'm buying.
Posted : 27/02/2016 2:35 pm
bongohoohaa - Member
Opened this thread just to check that someone had made the obligatory joke. Good work, carry on.
(Actually I do have both Pikes and a Yaris. The Pikes are ace, the Yaris is boring.)
Posted : 27/02/2016 2:58 pm
benpinnick - Member
Have they changed the design? Used to be you could drop a 160 to 150 with just an air shaft swap or mod
Posted : 27/02/2016 3:07 pm
That still stands, but Lyrik/Yari air shafts are rare right now.
Posted : 27/02/2016 3:12 pm
Ah, what a pain in the bum, that was a nice feature of the Pikes. Still able to cut down and rethread?
Posted : 27/02/2016 3:16 pm
Yeah you can, but wont be long before the parts & spares catch up to proper levels.
Posted : 27/02/2016 3:19 pm
Ah OK. Thanks for that, all filed away in the "what next" bit of my head!
Posted : 27/02/2016 3:21 pm
Lyrik/Yaris use Pike airshafts.
17 11.4018.026.001 air Shaft Solo air - PIKE (160mm 27.5/140mm 29), Lyrik/Yari(150mm)
17 11.4018.026.004 air Shaft Solo air - PIKE (150mm 29), Lyrik/Yari (160mm)
17 11.4018.026.002 air Shaft Solo air - PIKE (160mm 29), Lyrik/Yari (170mm 27.5only)
Posted : 27/02/2016 3:35 pm
Good shout - just Fishers need to catch up on their spare parts listing then (or I need to type in the right thing.. one or the other).
Posted : 27/02/2016 3:43 pm
Ben, can you do 180mm Yari for £408?
Posted : 27/02/2016 4:46 pm
Arrrrrgh just got in and seen your message about ringing.
Bet I've missed you now. I need to pay with PayPal, well it's where the funds are sat, is that ok?
Posted : 27/02/2016 4:54 pm
Pikes were at bike-discount.de
Posted : 27/02/2016 4:58 pm
Yep if its 27.5/100x15. Lyriks in the same flavour for £600.
Posted : 27/02/2016 4:59 pm
@moseymtb - Paypal charge a fortune in fees, so I try and avoid them. Its free for you to withdraw it though to your bank account. If its a big problem I can see if our paypal account is still active.
Posted : 27/02/2016 5:01 pm
I'd happily send it as gift to you as you're trusted.
It's just a hassle because my accounts not linked. I have the funds in my PayPal waiting you see.
Posted : 27/02/2016 5:03 pm
ok, drop me a mail on ben@birdmtb.co.uk and we'll sort out the details. Should be able to ship them Monday for delivery Tuesday.
Posted : 27/02/2016 5:05 pm
Fancy some new shiny stuff. Just about to order some new Yari forks and noticed I can buy the new full fat Lyrik charger damper for half the price to drop into my current 2013 Lyriks. Any thoughts on this option. Is the Yaris that good?
Posted : 14/03/2016 11:21 am
