shortening shimano ...
[Closed] shortening shimano brake hose
[#1290163]
not done shimanos before and couldnt find a step by step on their site. any hints and tips/ links/ step by step would be great.
cheers,
tom
Posted : 03/02/2010 9:03 pm
anyone?
Posted : 03/02/2010 10:06 pm
Do you know how to bleed them? Can help..
Posted : 03/02/2010 10:07 pm
stanley knife to cut, new olive and insert to fit, push pads most of the way into the caliper so once cut you can squeeze them further in and same with lever to ensure no air present when re-attaching.
simples.
Posted : 03/02/2010 10:08 pm
 jonb
I used the exploded diagram. I cut it, then reattached it. I filled the reservoir and pumped and they've been fine since, no need to bleed. Just keep the hose end high so no bubbles go down the hose.
Posted : 03/02/2010 10:11 pm
 TomB
I've got this to do on my new build, and frankly it scares me a bit, not sure why. Maybe LBS for me...
Posted : 03/02/2010 10:49 pm
cheers all, so ill need some mineral oil to top the system up then? just checking cos ive always used hopes and you can do it without losing any
Posted : 03/02/2010 11:42 pm
I got away without topping up my SLX ones. Did use new olive and insert though. The tricky bit was getting the new insert in without displacing too much oil.
Posted : 04/02/2010 2:07 am
ok, ill give it a bash. thanks all
Posted : 04/02/2010 8:51 am
