Short dropper post
[Closed] Short dropper post
[#12337741]
friend bought a Paragon Siskiu (small) but it came with 150mm TransXdropper (bl@@dy stupid). As bike has a bent set tube there's a load of post sticking out of the frame and it's far too tall for her - I reckon you'd need to be 5'9- 5'10 to ride it.
I think she'd just about get away with a 125mm dropper, or is there a dropper available with a lower 'stack' height? (if that's the terminology for the length of the inserted non dropper section)
or anyone on for a swap?
thanks
Posted : 09/04/2022 6:23 pm
oneup for low stack.
Others make kids posts
Posted : 09/04/2022 6:24 pm
If you were in Ireland id swap for my 120mm reverb.
Posted : 09/04/2022 6:41 pm
One up make the ones with the shortest insert length.
Posted : 09/04/2022 6:52 pm
I've just gone from a 100mm reverb to a 120mm One Up v2.1 on the daughters bike as the overall length was as compact as I could get it.
If a 100mm 30.9 external reverb is of any use, let me know.
Posted : 09/04/2022 7:02 pm
I was limited in choice for a dropper as I wanted an external one and have the same issue with a small frame and a bent tube. The thing that allowed me to fit one was using a 27.2 post with a shim down from 31.6. It made enough of a difference to use a Brand X post which wouldn't I couldn't have inserted far enough in 31.6.
Posted : 09/04/2022 7:23 pm
KS do a billion different lengths - good table showing post length here
https://kssuspension.com/product/lev/
Quite pricy though
Oh didn't expect that big ol graphic. Click the Read More for the chart.
Posted : 09/04/2022 7:32 pm
Giant do a little one as well. This is not a joke!
Posted : 09/04/2022 7:35 pm
 si77
One Up dropper has low insert length AND low stack (stack is the length that can't be inserted, eg the collar and the seat clamp).
Posted : 09/04/2022 8:07 pm
I use a 125mm Spesh one, for the very same reason
Posted : 09/04/2022 8:48 pm
Oneup and the new (must be the new version!) Fox Transfer have excellent minimal stack height. The design change from the old transfer meant I could go from a 100mm (marzocchi, but really fox) 'old' transfer to a 150mm new transfer.
Posted : 09/04/2022 8:53 pm
