Shockwizzers.....co...
[Closed] Shockwizzers.....compression on Fox RP23
[#9394718]
Anyone been messing with shockwiz for set up on a fox rp23? Been trialling it on last few rides and tweaking as I go along but it is still suggesting my slow and fast compression adjustment is out - not something that can be adjusted on a rp23 I think ? Could this be suggesting the shock needs a service or just the way the shocks is already tuned to suit the Turner sultan (DW link) - interesting bit of kit though!
Thanks
Posted : 22/06/2017 9:35 am
You can probably do stuff with shims during a service - that's basically how they arrive at the 'tune' the bike's supplied with.
I foudn the Shockwiz really interesting too - I need to spend some more time riding with one though.
Posted : 22/06/2017 9:37 am
I didn't do it with a RP23, but I found taking out a spacer on a Float EVOL and upping the pressure somehow resulted in the compression settings falling into the green zone. Not sure the science behind it though...
Posted : 22/06/2017 9:38 am
I've not going a shockwiz (yet) but my intention is pretty much that for my Pike forks. See what it says, remove a shim from the damper and see what difference it made.
Posted : 22/06/2017 9:42 am
