the black part is on of the bottom out pads ,the metal ring is possibly from the top of the white plate (damper seal head)
Brilliant
Where do i fit the bottom out pad? Only one came out and i dont know if i came out ofthe spring side of my coil or air or the damper side (turnkey or MOCO. As i said i took two forks apart at the same time. bad mistake.
I guess spring side?
Thanks
Lots of exploded views on the sram website eg:
[url= http://www.sram.com/en/service/rockshox/view.php?catID=1&subcatID=11 ]http://www.sram.com/en/service/rockshox/view.php?catID=1&subcatID=11[/url]
Remove the lowers and look into each leg, it will be quite apparent which bumper is missing.
happy again now thanks. found the missing pad.
