Shock service
[Closed] Shock service
[#3610432]
I´ve got a spare scott equalizer shock for my ransom but it needs a service. I accidently loosened the schrader valve when unscrewing the pump and it leaked oil.
I can get it done here in Spain but its 120€ plus postage. I was wondering where can you get them serviced in the UK and how much does it cost? Since I´m not in a hurry I don´t mind a long postage turnaround time.
Cheers.
Posted : 26/01/2012 12:51 pm
 LoCo
Speak to the Pace suspension service centre, or the Scott distributor (although I guess they would say send to the Spainish distributor)
Posted : 26/01/2012 12:53 pm
Being a Ransom, it'll be an Equalizer 1, in which case it's Evans Suspension (Pace only do the EQ2/3 shocks).
http://www.evanscycles.com/servicing/suspension-servicing
Posted : 26/01/2012 1:26 pm
So probably cheaper and easier to send it for service in Spain once you've added the postage on.
and 'full service' rear shock service at £45, that'd be an air can service then 😆
Posted : 26/01/2012 1:35 pm
Cheers for the replies.
Pace don´t service Equalizer 1´s and using Evans it´d work out the same price as here. I´d heard they were pricy to service.
Just as well I can do it myself when it comes to the turn of my Lyrik forks.
Posted : 26/01/2012 4:28 pm
Hi, if I where you I would swap the equalizer out for a DHX Air 5. I'v been riding a Ransom with a standard shock for 4 yrs & no real issues apart from a regular service but last summer put a Fox DHX 5 Air on it with a low volume can & wow rides so much better
Posted : 08/02/2012 8:54 pm
Give James a try...
[url= http://j-techsuspension.co.uk/ ]J-Tech[/url]
He will sort it out for you.
SB
Posted : 08/02/2012 9:12 pm
