Shock reducer remov...
[Closed] Shock reducer removal
[#1429275]
I'm going to give my Fox RP23 an aircan service.
Because the reducers fitted to the shock are wider than the diameter of the aircan I need to remove them to remove the aircan.
What's the best way to do this without damaging them so I can refit them once I've given the shock an aircan service?
I'm thinking pliers with tape wrapped round them at the moment, any other suggestions.
Posted : 20/03/2010 10:26 am
tape and vice-twist and pull
very easy to chew them up with pliers
Posted : 20/03/2010 11:52 am
Ok, thanks.
I've just been fiddling and have noticed a bit of play in the rear suspension.
I've checked all the bolts on the linkages aren't loose, and the bearings in my frame (2009 Giant Tracncex) where only changed about a month ago.
I'm 95% sure it's the shock bushings.
Is it best to just order a new kit with the reducers and all or just replace the bushings themselves and use the old reducers?
Posted : 20/03/2010 1:50 pm
the reducers should be fine, the bushing is designed to wear first,
Posted : 21/03/2010 6:41 pm
Thats what I thought.
I'm glad too because I've ordered a couple off Ebay for under £3.
The whole mount kit is more like £20, wouldn't be happy shelling out that much if it happens regularly.
Posted : 21/03/2010 6:49 pm
you can get a nice little tool for about a tenner for pressing them in and out on ebay too, i got one and it works a treat, much easier than using a vice and sockets
Posted : 21/03/2010 6:53 pm
Ye thanks for that.
I actually ordered one yestarday at the same time as the bushings
Looks like it will be well worth the money especially if it happens regularly.
Posted : 21/03/2010 8:05 pm
