Shock pump
[Closed] Shock pump
[#224592]
I am after some advice on which is the best shock pump to use on a Fox RP3 that is fitted to a Whyte E5.I am having difficulties connecting the one i have to the valve on the shock due to there being no room to get your fingers in.Does anyone know if you can get a pump with a longer valve attachment.
Thanks
Posted : 18/01/2009 5:45 pm
rock shoxs ones are quite good
Posted : 18/01/2009 8:39 pm
 fbk
My fox one works ok. Agreed, it's fiddly to screw onto the valve but, given the position of the shock, I thick that'd be the case whatever (E5 too)
Posted : 19/01/2009 11:12 am
