shock mount bolts o...
[Closed] shock mount bolts on a 5 - do they wear ?
[#2727873]
just wondering - shock going for service soon and will be gtting new bushings - do the mount bolts and sleeve wear and need replacing with time ? I'm guessing the bushings are designed to take the wear so probably not ?
Posted : 07/05/2011 10:48 pm
Hi
they shouldnt
as you rightly said the bushes are the wearing component .
Posted : 07/05/2011 10:52 pm
mine did, bike was 18mnths old before i thought to check the pivot bearings and found one side had collapsed but the other was ok. noticed that the bolts had bent slightly they also felt a bit thinner in the middle (no digi caplipers to confirm though)
so yes they do wear/bend etc but if this maybe caused by something else,, as above.
Posted : 08/05/2011 3:45 am
If you're bending shock bolts, it's usually because you've bottomed-out the shock and transferred the load into the bolt.You may want to consider upping your air pressure/altering your compression tune.
Posted : 08/05/2011 7:30 am
