Shock leverage rati...
Shock leverage ratio??
 ton
[#13274418]
Am I right in thinking that the lower the shock ratio is on a bike it is more suitable for a heavier rider ?
Pretty sure this was the way back when I had a full sus bike.
Any info greatly appreciated
Posted : 02/06/2024 1:57 pm
It means it will need a longer travel shock for the same wheel travel. So, yes, the shock won't be under as much stress and you can run lower pressures or use a softer spring.
Posted : 02/06/2024 2:04 pm
