Im getting around to changing my rear shock on my pitch. Just wondered if anybody knew the measurements i need. I want to keep the travel the same. Also wondered if anyone would recomend a air shock or coil ? Any help will be appriciated
here you go.
http://www.pinkbike.com/forum/listcomments/?threadid=60890
or tech page on this
http://www.specialized.com/gb/en/bc/SBCBkModel.jsp?sid=10Pitch
I swapped the stock X-Fusion on my Pitch comp to a DHX Air 5.0, did wonders.
It's a 200 i2i and 50mm stroke, I got mine from Mojo a couple of years ago in one of their spring sales, paid about £125 for an '08 model.
It really suited the Pitch when coupled with Fox Van 36 R's up front.
Gratuitous photo opportunity time 😆
[img]
[/img]
If it's a Pitch Pro with an RP2, then you're wasting your time getting another air shock. A DHX won't perform any better. Coil would be the way forewards. I fancy a simple Vanilla R myself..... Just to try out! 🙂
As khani says its 200 i2i and 57 stroke
Cheers all
The shock ive got in at the moment is a x fusion so it has to go
Last question
DHX Air Or RP2 ?
Thanks again
RP2
I put an RP2 on mine to replace the clank-a-lank X Fusion and it was great. I then swapped it for a DHX 4 which was nice and plush but made the bike a little slower to climb. This became academic though as the bike then wemt single ring with 180 marzocchis and it now my downhill bike ;o)
